Old 10-13-2022, 09:58 PM
I like your "Special Tool" Get-R-Done I think replacing all the O-Rings will solve your issue with the valve assembly. Certain Tards should not be allowed near anything mechanical. The drain plug issue brings back memories of an idiot that serviced machines for a excavation company I worked for years ago. I did the next scheduled service and had to use my 2' Snapon Breaker bar with a 4Ft cheater to break it loose WTF. I also had an oil filter that defied all normal means of removal. Filter wrench just slipped. Drove a Bigass screw driver through it the filter body just tore loose from the base. Ended up using an air chisel stuck into the holes in the filter base. Probably close to 2 hours to remove an oil filter
Old 10-14-2022, 07:38 AM
Viton is a better performer at higher temps, but buna is better at low temps. Viton is a slight bit stiffer too, which can be good or bad. Sometimes it makes them harder to assemble, though a little tougher and more damage resistant.
Take a good look in the area where the damaged o-ring was, make sure there isn’t some rust, or a burr or anything that may have lead to the damage.
Old 10-14-2022, 07:23 PM
That's helpful, Mark. I think I should go with Buna as cold weather is when I am pushing snow.
Old 10-14-2022, 10:19 PM
Default Brake valve issue
I don’t recall the temp specs, and we were using them at or above room temps anyway. Some searching should find the lower temp specs for you.
I’m scratching my head on what you can use as an assembly lube. What is the fluid it’s in contact with? Brake fluid or hyd oil?
Old 10-15-2022, 08:19 AM
Hyd oil from the transmission. It uses a TGH oil.
