Old 12-15-2020, 06:04 PM
Originally Posted by OldRedFord View Post
I'm amazed this thing will run.
After that I got a list of parts to get it useable.
This is when you go over your neighbor's house and see if you can find the rest of the missing parts...
TA 95 lunchbox w/tig
Old 12-16-2020, 02:48 AM
Rob65 Rob65 is offline
Lost the one special bolt for the swimg arm bushing so that's the first thing.
Starter relay....its missing
Ignition switch...its broken
Banjo bolt to hook brake hose to master cylinder...missing
Ignition coil/plug wire. Need a new plug wire. Boot is cracked where it fits on the plug.
Choke lever assembly. Missing the screw to hold it on and a spring.
Seals for swing arm bushings.
Dust covers for bushings.
Bolt to mount shock to swing arm.
As of now I've got $200 invested including purchase.
Wot ya doing ordering special bolts?
You have just taken delivery of a lathe. The only thing you might be missing is a bit of bar stock.
The way it’s supposed to work is use ‘boy toy’ number one to build / improve ‘boy toy’ number two and so it goes on.....
The only problem is having enough hours in the days to do all this stuff.
Old 12-16-2020, 06:27 AM
That’s the way to learn new skills fir sure.
Old 12-17-2020, 06:30 PM
From that required parts list, it sounds like a Honda Recon MIA.
Old 12-17-2020, 08:38 PM
That s a good one!!!
Old 12-20-2020, 08:36 PM
OldRedFord's Avatar
Kibble King
Got it back together. Need to replace the brake cables.
Runs fair but will not idle. What should I check?
Tim
Old 12-20-2020, 10:30 PM
MotorDoctor's Avatar
MotorDoctor MotorDoctor is offline
Karma Avenger
Been sitting a long time? Carb clean and clean the pilot jet/passages/fuel screw. Set the screw @ 3 turns out to start. Why won't it idle:
  • Carb plugged/old fuel/contaminated fuel/rusty fuel tank
  • Air leak between the carb and the engine/usually @ the rubber manifold
  • Valve clearance is too tight, usually the intakes
  • Compression is low
  • Cylinder leakdown is excessive
  • Cam timing is off (see compression)
  • Venting to carburetor
  • Erratic spark/spark plug cap/plug wire/corroded wiring/battery terminals/spark plug
Director of Sarcasm (by appointment) Director of Innuendo (by suggestion)
