Old 03-24-2018, 10:50 PM
Default Mixer
Nothing much to do tonight. K'kins is off at her Mother's watching the basketball thing. We don't have cable here at the house.
What I'm doing, is taking a vintage Monkey Wards mixer, and re-purposing it to run on a 3pt.
The frame is where it's at for this stage of the build. It's not going any further till I get my lather running.
Name:	concrete mixer2-1.jpg
ID:	144125   Click image for larger version
Name:	concrete mixer92-1.jpg
http://www.farmersamm.com/
Old 03-24-2018, 11:04 PM
The transmission, and some welds. I like welds The little skinny pic is of a weld redo. If it ain't right, it gets redone. Had a heat issue with the first weld...........too hot, and throwing dingleberries everywhere. Grind out, and redo. I feel that the best welders are the guys that suck it up, and fix their mistakes.
And some shrinking to keep it all straight.
Keep the thread going till it's done.
Another quality design straight from Uranus
Name:	concrete mixer130-1.jpg
ID:	144127   Click image for larger version
Name:	concrete mixer129-1.jpg
ID:	144128   Click image for larger version
Name:	concrete mixer132-1.jpg
ID:	144129   Click image for larger version
Name:	concrete mixer76-1.jpg
ID:	144130   Click image for larger version
Name:	concrete mixer84-1.jpg
Old 03-25-2018, 06:18 PM
So it used to run on a simple 120 volt plug, and now you need to hitch
it up to the 3 point ?
Or hang a $99 HF 6.5 HF Chonda on it.
Sounds like a step backwards, what is the impetus for the 3-point mounting ?
Old 03-25-2018, 06:25 PM
There are times when my two electric mixers are just a pain to have everything in close proximity to where the pour is to be.
I've thought of having a larger mixer on 3pt to do the same thing, being able to get closer to just pour from the mixer without having to haul a wheelbarrow etc.
I may do this with one of mine, but keeping the electric drive intact and just run with it after the mixing is done and plug it back in at the point of pour.
Will be looking forward to your build.
Old 03-25-2018, 07:10 PM
Neighbor want's one in the worst way...(keeps talking about it,
complains there aint any local, but yet won't drive 50 miles to get
one.....)
Wants to do fence post's, out on the back 40.
With a 30 hp NewHolland (with front loader) I told him
to load the front bucket with premix bags, and a barrel of water.
If he would unfold the ROPS (never has since new.....) he could make a rack
to carry the fence post's up top.
That way, he can sneak down the fence row (between the trees, and the fence)
He would have it all with him, for a day out in the pasture.
Old 03-25-2018, 11:02 PM
We have an upcoming fencing project, some pads for underneath the stock tanks, and some other stuff.
K'kins, and I, are too old to mix mud by hand anymore. Well we could, but it wouldn't be pretty
The fencing project is going to have multiple corner posts, and pull posts. Pasture is irregular plot of land due to trees. The 3pt mixer allows us to load it up, mix on the go, and dump in rough terrain. I can keep concrete sacks and water on the carryall on the other tractor, and just use it as a sort of base that I can return too for more ingredients.
I've seen some of the offerings at Northern Tool, and other places. All flimsy import stuff badged with different names. Don't see them holding up for even a day. https://www.agrisupply.com/cosmo-cement-mixer/p/28537/
And...........3pt..........PTO powered........hitch and go. Makes life pretty easy. No messing with gensets, or using the welder to run it.
We've been sort of gearing up for this over a long period. Built pallet forks for moving pipe, and concrete. Built a man lift for the pallet forks so's I can erect steel for a new loafing shed, and trim trees. Built a carryall for heavy loads. Now the mixer. Builder Bob is in da house
Old 03-25-2018, 11:35 PM
All the goodies
ID:	144156   Click image for larger version
Name:	bonus3 - Copy.JPG
ID:	144157   Click image for larger version
Old 04-02-2018, 04:08 PM
Been thinking on this some more....
If you mount this cement mixer in a angle iron (probably 2 x 2 x 1/4")
cage, you could put 3 point pins on 3 sides.
That way, you can dump it off the back, off the right side, or off the left side.
Old 04-02-2018, 11:09 PM
Farmersamm.....JIMO!
I can see the need for it for pad pours....... but for planting fence post and corner H braces It just as effective if you just dump a little water in the hole with he post in and pour a half bag in use half inch round bar and tamp it around
pour a little more water and rest of bag in tamp it a little more and go on to the next post or H brace
fencers have been doing that here for 20 or so years and post are still solid as if ya spend all that time mixing and pouring....
but the mixer will be a must for mixing to pour pads and such larger areas.
Old 04-03-2018, 02:45 PM
Dr Dean's Avatar
Dr Dean Dr Dean is offline
no bull it's huge!
I'm still trying to figure out why you have to cement a wood fence post into a hole. I was taught to put a little soil in at a time and tamp it with the spade handle they were always tight in the ground and the fence is usually good for 40 years or so.
