Old 01-01-2009, 04:20 AM
LW Hiway's Avatar
LW Hiway LW Hiway is offline
Lord of the Minions
Default Induction Heating: the process of or any past experience
Has anyone here had any hands on experience with using shop sized induction heat equipment. Coils and power supply etc.?
Old 01-01-2009, 09:44 AM
We used to heat bearings and such . Worked great warm them up drop them on 4-8 inch shafting.
Old 01-02-2009, 03:15 PM
I don't know anything about them. I took these pictures about 2006.
This one sprung a leak and flooded everything with antifreeze.
After 20 or so years the plastic hoses crystallized and broke.
Induction casting machine.
220 volts @ 22 amps
(1) basic picture
Site glass on top and IR. temperature sensor.
(2) Closer look
(3) Other side.
White glass tube. just to the lower left a large 3700 volt transformer, maybe +35 lbs.
Center coolant line.
I removed the transformer and bench tested it.
(4, 5) coolant lines.
The pictures show outside copper lines that enter a compartment where the actual coils are housed.
I wasn't able to get a picture of the coils in the housing.
I believe they are standard copper tubing and the plastic lines that supply coolant, use compression fittings.
I seen this one go on e-Bay for $300 to $1000. weight is about 350 lbs.
ID:	39692   Click image for larger version
ID:	39693   Click image for larger version
ID:	39694   Click image for larger version
ID:	39695   Click image for larger version
Old 01-02-2009, 04:17 PM
Forgot to say it on the last post. We did test on Al rim and Disc where we heated the rim with a big coil and dropped the disc in rather than pressing.It had real potential as far as reducing run out scrap .We had the line speed to handle 600+ per hour but could never get the cost to benefit ratio to company payback requirement.
