Old 04-01-2009, 10:08 PM
Default Poor performance from my MM200
I have this MM200 that I swapped for my MM185 for the higher amp output a while back. It seemed to weld fine on thin tubing, but when I welded 1/4" and up it didn't weld well at all, lots of spatter, irregular wire feeding, poor penetration, etc. I also switched to CO2 at the same time due to needing a fill and they wanted $75 for a c-25 fill. I thought part of it was the CO2, and me not being used to it. I just finished a large project and decided it was time to figure it out.
I removed the covers and removed/brushed the big wire terminals as well as the chassis ground wire and input wire terminals. I wire brushed the contacts on the voltage tap switch, these were, I suspect a part of the issue as they were not bright by any stretch. I also cleaned the contact the rides on them. I the disassembled the contactor to look at the contacts and was amazed by the amount of corrosion on them and that they were still working. Cleaned them off with sand paper but wonder now if I should find a points file to use on them, we'll see. I also switched to .030 wire for a lighter gauge job I am doing next. I also switched wire brands from the house brands at Praxair to and spool of Lincoln L-56. The results were spectacular. It welds so much better now, I only wish I had done these things one at a time to see what really did the trick. I guess when they say in the manual to do these sort of maintenance issues once or twice a year I should perhaps look into it. As it is I am sure they have not been looked at for 20 years so I suppose it is impressive that it welded at all.
Old 04-01-2009, 10:12 PM
It is the CO2. I hate welding with the shit. I am sure someone will follow me
up and say it is not but I have never seen a CO2 weld I liked.
Old 04-01-2009, 10:41 PM
cutter cutter is online now
I'm finding the same thing with my little welder - the HH135 won't run a bead with CO2. It just sputters.
Old 04-01-2009, 11:22 PM
chumly2071's Avatar
Urban Gunfighter
Something else I have found is that it is import to use some solvent and clean the wire drive rollers. The last two welders I bought recently had bad sputtering problems. I ended up cleaning the rollers with brake clean and a rag, and they fed like champs after that...
Old 04-01-2009, 11:25 PM
Director: Fish Seduction
I'll be the "someone". I like it, a lot. The extra penetration is the main selling point for me. C25 is still cleaner, and that's what I'm using now.
At the same time though, I refuse to buy another roll of Lincoln wire.
In any case, I'm glad it looks like you got your machine straightened out with all the little changes. Doesn't really matter which one worked, so long as it did.
Wade's Custom Kydex
Old 04-02-2009, 12:43 AM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
+1 on the CO2, its what I learned on and every employer that has paid me to weld uses it too.
Ory-gun Boy!
Old 04-02-2009, 12:19 PM
I was at the LWS supplier today, at 110 cuft cylinder of CO2 was about $17 and a 110 cuft bottle of 75/25 was $21, both prices are with an exchange of bottles. With only a $4 difference between the two, I see no reason to buy CO2. I hate welding with CO2, and use it only when welding with Lincoln Outershield wire that specifies CO2 shielding gas. I only use the 75/25 on the MM180, as I use 90/10 on the MM350P.
I usually run Lincoln L-56, and have for years, I had a bad roll last year the the LWS exchanged, and the rolls since then have been fine.
Jack
Old 04-02-2009, 01:23 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
Sold by the lb
1lb= 8.74CF
Conversion of a 110cf bottle would be 12.58lb bottle of Co2
Ed Conley
MM211 AS
MM252
Spoolmate 100
SO 2020 Bender
Miller 125c Plasma
TA 185
Old 04-02-2009, 02:06 PM
Originally Posted by Broccoli1 View Post
Sold by the lb
1lb= 8.74CF
Ed,
I'm just going by the quote the LWS gave me, the cost difference between 110 cuft of CO2 vs 110 cuft of 75/25. And it was $17 for the CO2 and $21 for the 75/25.
Old 04-02-2009, 09:36 PM
TriHonu's Avatar
TriHonu TriHonu is offline
Walker - I also have a MM200. According to the Techs at Miller, it is one of the best welders they ever built.
They told me the MM200 may lose some power over time. If you notice that you have to weld in a higher setting than you used to, it can be caused from the capacitor bank getting weak. At some point you may have to replace the set of 6 or 8 (I don't remember) capacitors. Other than that it sounds like you have already done the other things they told me to watch for.
Around my parts, they still bring good money. The last two I saw sold for $900 and $1000. Still a lot of demand for these machines.
