Old 02-09-2017, 12:23 AM
gimpyrobb's Avatar
Originally Posted by weldor2005 View Post
Our stored pressure ABC (Dry chemical, not CO2) units are pressurized at ~125 psi.
I am starting to wonder where this thread has morphed to? I thought we were keeping it simple and safe for kids, and now we are looking at heavier metal projectiles fueled by hydrocarbons?
Originally Posted by JBFab View Post
Ya know, your absolutely right. My apologies to gimpyrobb for dragging this thread off the rails...
No worries guys, I am not on a "mission", I mentioned it to my best friends kid and he wanted more info. I might just make a quick and dirty one that we can tweek.
I enjoy the tangents. I once saw a guy put a mix of oxy/acet into a spud gun for a distance attempt. I will NEVER try that one.
Old 02-09-2017, 12:37 AM
TEK's Avatar
TEK TEK is online now
Originally Posted by gimpyrobb View Post
No worries guys
Why not? Did it burst on him?
Some of the mechanics I worked with made a launcher out of hydraulic tubing that had been ruined. It would shoot a 'D' sized battery almost out of sight..it was oxy/acety fueled
We had great fun shooting at ground squirrels about 500 yards away
-----DozerDan
Old 02-09-2017, 12:44 AM
My daughter created this aircraft for a science project in middle school. The tube is a florescent light protection tube with a plastic Easter egg for a nose cone. Cardboard fins and a bunch of duct tape as well as a 2-liter bottle round out construction. I believe they used a manual tire pump to pressurize the vessel but I don't know the pressure they went up to.
Old 02-09-2017, 08:55 AM
gimpyrobb's Avatar
Yup, it shattered quite violently. I was amazed he wasn't hurt.
Old 02-09-2017, 02:11 PM
Norm W's Avatar
Norm W Norm W is offline
A tire seating air blaster (I'm not sure what they are called) with the air pipe replaced with a straight pipe makes a great apple gun. An apple, just slightly larger than the tube, and crammed into it will go a couple of hundred yards. The rate of fire depends on the size of the compressor used to recharge the tank. It could be used for spuds too, but we had a bunch of inedible apples so that is what we used.
Old 02-09-2017, 03:02 PM
Originally Posted by Norm W View Post
A tire seating air blaster (I'm not sure what they are called) with the air pipe replaced with a straight pipe makes a great apple gun....
My young one welded up a fitting to a 20 lb. propane tank and added one of those fast pneumatic dump valves as are used to blow debris out of dust collection systems. I think it's maybe 1.5" ID. He added a 10 foot pipe barrel (2 - 2.5" ?). Thing is scary. Never took it to a place big enough to test it for distance.
He had another made from PVC with 3 big pipe reservoirs and I think a couple of those lawn sprinkler valves. It would be ideal for launching rockets made from paper tubes covered with masking tape.
http://makezine.com/2008/12/13/compressed-air-rocket/
