Old 07-27-2004, 04:46 PM
Mikey
Guest
Posts: n/a
Default New Grinder
Well, being as old and clumsy as I am, I dropped my $10 HF 4" grinder and it quit. I spent awhile taking it apart, and drinking beer and no joy. My time is worth something, right?
Anyway, I needed one quick and went to town to Home Depot. I had no idea what I'd get. The Makita's were there, but pricey. Milwalk's...same thing.
I picked up a Ryobi 4.5" kit for $40. Got it home, and was pretty dang impressed. The new style has a real handle, like the 7", a lock on switch, one each of a grinding wheel, brass wire brush, and flap disc. All in a case that really works........So, I'm happy. Not a Makita, but a step up from the HF junk, I'd say.
Question: Where DOES the 4 and half incher place in the scheme of things?
Just more amps/power, or is there a real purpose behind this size>?
Just wondering..
Old 07-27-2004, 04:50 PM
arcdawg arcdawg is offline
i really like mine......chicom
its nice to have a lil one handy for getting into tight spots and portabilty
rocky...over on hobarts site has like 4 or 5 of them on his welding cart.... all have diffrent wheels on them.........prety cool idea
dawg
Old 07-27-2004, 05:11 PM
'Ol Pilot
Guest
Posts: n/a
I have several 4 1/2" grinders - mostly HF's. I keep a cutting disc on one, a grinding disk on one, paint removal disk on another, etc. Makes it convenient. Maybe I'm just lucky, but I have yet to wear a $20 HF grinder out and they even come with extra brushes. And I can have at least three for the price of my Dewalt. If you are doing any light square or round tubing, that cutoff disk on a 4 1/2" grinder can be really handy. Saves using a die grinder or dragging out the cutoff saw or bandsaw.
Old 07-27-2004, 05:19 PM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
Just has a little bigger wheel, some have more power. I have been using the DW402's from HD 79$ and they have the power. The only thing I dont care for about them is the spanner type nut. I like hex so any crecent style or 7/8 wrench works to change wheels. I have about 5 of them and the only other thing to watch for is the brushes, need to change them about a year of hard use, if you let them go it will cook the armature. Here is a shot of the ones under one bench, I have another half a dozen around.
Old 07-27-2004, 05:36 PM
Mikey
Guest
Posts: n/a
Really sweet! Say, does that AC oulet there on your table affect anything?
Old 07-27-2004, 05:45 PM
7018's Avatar
7018 7018 is offline
I've got about 6 of the 4 1/2 inch grinders there real handy,But u can work them to hard>It will Blow the gears.
Old 07-27-2004, 05:48 PM
banzaitoyota banzaitoyota is offline
Send a message via AIM to banzaitoyota
As a rule of thumb: I disassemble ALL my grinders ( 2 dewalts, A HF cheapy and a Homier cheaper) and regrease the heads and sand the commutator every 6 months. Makes them HAPPY HAPPY!!1
Old 07-27-2004, 06:08 PM
Sberry's Avatar
Sure does,,, makes it easy to find an outlet !!!!!! Ok,,, enough wise ass huh? My benches are interconnected and bonded to the building so I ran only a 2 wire circuit and used the welding bond for a ground fault return path. I also have gfci on the circuit that feeds the benches. If you have a stand alone bench its fine to connect a grounded electrical circuit to it. My situation is a little different since there is a steel imbed in the floor so I had to do some things different to insure that the electric equipment ground didnt become part of a welding ground loop. On a single bench it wouldnt be a problem though.
Old 07-27-2004, 06:11 PM
Sberry's Avatar
The chop saw has since been moved to its own bench.
