Old 01-10-2021, 05:16 PM
Default Box Joint Sled
I got a 6' tall drawer rack from Bubba a couple years ago and decided to get with the program and make some drawers for it to store tooling for the mill and the lathe. Tooling for the mill is sitting on the bench under the mill gathering all kinds of dust.
The drawer rack was built for electronics. The drawer slides are full extension. Got the slides put in a couple days back. Will have a couple 10" tall drawers and the rest will be 2",4" and 5". The slides are not yet set by drawer size yet.
I have a adjustable dado blade I have had for years, but it is only 6" so I needed to get an 8" in order to raise the blade high enough on the table saw. Got a Diablo stacked set made by Freud that will do 1/4" to 7/8" dados. I am doing 1/2" dados for these drawers.
Using some 1x6x8' pine I had stored out in the pasture semi van for the last 4 years. I will need to get some wider boards for the taller drawers. The dado set has a shim set from .002 to .06 for fine tuning.
Had to build a dado slide for the table saw to make it all work. Copied the design here with a couple changes.
Still have not decide what to use to cover the outside of the drawer rack yet. Probably use some 1/8" paneling I have out in the hay barn to keep the dust out.
ID:	159119   Click image for larger version
ID:	159120   Click image for larger version
ID:	159121   Click image for larger version
Old 01-10-2021, 05:22 PM
More pics. Drawer bottoms will be 1/4" plywood. A couple test samples and the small piece in the last pic is used to start the dado offset for the drawer sides. Drawer dimensions are 19" deep and 16-3/4" wide
ID:	159123   Click image for larger version
ID:	159124   Click image for larger version
ID:	159125   Click image for larger version
Old 01-10-2021, 06:57 PM
Nice, I have always liked the look of a good box joint.
Old 01-10-2021, 07:52 PM
Me too. Unfortunately I am finding the 1x6 boards are not a uniform width. Seems I should have ran them through the table saw prior to doing the dados. Now I will need to run them through the table saw after assembly to make them a uniform width. Not a big deal just more work.
Old 01-10-2021, 08:30 PM
Now that you've got that figured out make those corner joints in a dovetail...
Old 01-10-2021, 09:11 PM
I have a dovetail jig. Make nice joints too. This time just picked the box joint.
Old 01-10-2021, 10:21 PM
Nice! I think I would make two three footers, Is that a old Black and Decker drill stand back there?
Old 01-10-2021, 11:00 PM
I will look tomorrow and take a better pics. It is a gear reduction so larger bits work well.
Old 01-11-2021, 08:34 PM
Got all the dado slots cut this morning. Then cut the 1/4" plywood drawer bottoms and glued up the first drawer. Hope to glue up a few more drawers tomorrow.
ID:	159144   Click image for larger version
Old 01-12-2021, 06:16 PM
Sorry, a day late. It is a Van Norman gear reduction.
ID:	159153   Click image for larger version
ID:	159154   Click image for larger version
