Old 01-20-2019, 07:55 PM
if its buried its PVC otherwise emt.
Old 01-20-2019, 10:18 PM
Norcal Norcal is offline
Unless it's underground, or needs corrosion resistance, EMT.
Old 01-21-2019, 04:29 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
EMT above ground in dry locations.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 01-21-2019, 07:17 PM
kbs2244 kbs2244 is offline
I did not think about underground installs.
That is a whole different world of needs.
Due to local variances,
I would go with the local experience.
Old 01-22-2019, 11:03 AM
jpag jpag is offline
I recently finished building my shop. I ran 4" PVC underground for the 400 amp service. For all of the wiring in the shop with the exception of the bathroom which I used MC cable it's completely done in EMT. I made runs from the panel up to where the wall meets the ceiling and then dropped down every other 6x6 and hit a double duplex receptacle, with each receptacle on its own circuit. I have a 200 Amp 42 circuit MLO panel on the big side of the building and then a 100 Amp MLO panel on the shop side.
