  #1681
Old 06-06-2022, 06:26 PM
OldRedFord's Avatar
Kibble King
Prep for a partial plumbing inspection.
Tim
  #1682
Old 06-06-2022, 09:43 PM
randydupree's Avatar
Why, Hell Yes!
do you have a well yet?
  #1683
Old 06-20-2022, 05:48 PM
OldRedFord's Avatar
Kibble King
No. Should have done that sooner. Didn't foresee diesel getting this high.
Also my Square D QO panels are all included in the big Square D recall. Way to go.
Tim
  #1684
Old 07-12-2022, 07:45 PM
OldRedFord's Avatar
Kibble King
Pressure tested my supply lines. 80psi for 15 minutes.
I have a slight leak at a threaded fitting at my shower valve. Interesting to note that the pressure gauge does not move at all during the 15 minute period but does if I leave it longer. Found it by spraying joints with soapy water.
Tim
  #1685
Old 07-14-2022, 06:26 AM
Why, Hell Yes!
did you use pipe dope or tape?
i have found in recent years that the pipe dope/sealers are not as good as they used to be,i have been using the blue stuff.
Its the best i have used in a long time.
  #1686
Old 07-14-2022, 05:52 PM
My plumber blames it on the pipe threads over the sealers. He turned me on to using both the tape and the paste. So far its been working for me.
  #1687
Old 07-14-2022, 06:35 PM
Why, Hell Yes!
I suspected the threads were not so good,and i have used tape and dope in combo before.
total bullshit that we can't make good threads..
  #1688
Old 07-15-2022, 11:25 AM
OldRedFord's Avatar
Kibble King
I used tape. When I put them back together using dope.
Tim
  #1689
Old 07-17-2022, 08:36 AM
Since 'we' don't make pipe fittings anymore, they are made in Malaysia and China, they tend to use the Japanese straight thread , The inventors of metric never succeeded in creating a tapered pipe thread so settled on inch thread, but had to be different so they made a taperless thread with brass washer as standard. Check sensors for oil pressure in a Toyota engine.
For most water applications, this misfit will work, when you screw a tapered nipple into a Malaysian straight pipe 90. It may drip for a minute and seal.
Not so for oil. I have had to re-thread 1/8" fittings to 1/8"NP taper for oil pressure as they will always leak unless you do.
  #1690
Old 07-17-2022, 09:15 AM
Since 'we' don't make pipe fittings anymore, they are made in Malaysia and China, they tend to use the Japanese straight thread...
I have heard this, but I have always check my pipe fittings in the store
so far all the China and India fittings are tapered.
