#51
My real concern is the little gearbox. That Bison was a very expensive little motor when it was new. I see used ones listed on ebay now for as much as $500 and I would really hate to cause it to eat itself for lack of not trying to make it right. Quote:
But it is an old chain and I might should try another piece. Quote:
One odd thing I discovered is that the threads on the two bolts are slightly different from each other. They look the same but the nuts will not interchange. Very odd.
#52
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
#53
1) Your mount Replace the two hex spacers with ones that are threaded completely through like coupling nuts, This will allow you to tighten the motor mount to the head casing on the "one side" with bolts (so the motor mount does not slop around). Studs with nuts on the opposite will allow you too still clamp or un-clamp the head....
#54
But I had come to believe that it must be the chain because I think the alignment issues have been sufficiently tweaked so it must be the chain. So Wilson & I loaded up late this afternoon & sashayed over to Tractor Supply for dog chewies and roller chain. Damned if they weren't sold out of chewies. Their sense of civic responsibility is highly questionable. But Wilson loves to go shopping at Tractor Supply anyway so he enjoyed the extended sniffing exercise. They did have a couple of 10ft rolls of new Chinese chain & a package of master links, which it turns out I didn't need since they packed one with the greasy chain. 1. showing the ends at the start 2. about ten links along the way. You can see it beginning to creep, yes? 3. by the time we reach about 20 links, the old chain has gain half a link. 4. by the time we get to the required length, we have almost a full link difference. And this is lying slack, with no load to stretch it. 5. And finally, since this is Show & Tell for Dave Lee and 1911man too, here are a couple of frozen chilicubes to reinforce the suggestion.
#55
So once again, did it solve the problem?
I am satisfied.
#56
Nice job Rod, I always enjoy your stories.
"The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it." “The thing about quotes on the internet is you cannot confirm their validity” Abraham Lincoln |
#57
I guess the next thing would be add a Harley chain oiler.
#58
And it looks like Mildred is too.
#59
looks naked without a one-shot oiling system.........
jack |
#60
By George, I thinks he's got it!
Chillicubes, mmmmmm. Gotta get me some more chilli. I think the open can in the "fridgerator" is about a month and a half, old Last night, I had two, sliced-up hot dogs in half a container of Bob Evans smashed potatos. Them 'taters is tasty! Dave
Hoocha Momma!, who chop-id-da cheese? |
Tags |
gearmotor, harbor freight, head lift, mill/drill |
