Old 07-16-2005, 11:01 AM
Matt
Guest
Posts: n/a
Default Pictures of welds off a truck
Thursday at work I was repairing a section of floor on a 53' trailer. There were some aluminum plates welded in place as braces that needed to be replaced as part of the repair. So I was preparing to use the plasma cutter to wash out the welds and then be able to pull the plates up. Well, my boss walks up and he points out that most of the welds are already broken, so sends me for a pry bar and with little effort, pops the plates out like they were duct taped in. I saved one of the plates so I could show you guys some pics of these fine weld specimens.
This one is a pic of the bottom, in which you can see there was no fusion.
Old 07-16-2005, 11:31 AM
Pile Buck's Avatar
North West Redneck
Hey Matt, I know who made those welds! There is a kid on here, who post pictures of welds just like those!
Old 07-16-2005, 11:57 AM
Spider Spider is offline
That should be a picture in the welders dictionary under the term
"booger weld"
Da Gmail Bandit
Old 07-16-2005, 12:06 PM
Looks like it was welded with one of those 90 amp wonder machines....
Old 07-16-2005, 12:37 PM
Franz Franz is offline
Banned
Naw, those were made with one of them plastic spool guns you hook to yer off road rock climber battery.
Hell, they looked good enough to convince Matt he needed to cut em out.
Matt, take alesson from it, spend a few extra minutes lookin at the job before you start haulin equipment out. Planning how you'll do the job can often save a lot of muscle work.
Old 07-16-2005, 03:43 PM
King of Obsolete's Avatar
Published Author
wow those are birdsh*t welds, i suppose that the fellow got $65.00 per hour to do that kind of work.
thansk for sharing
Old 07-16-2005, 04:56 PM
Hickey Hickey is offline
Sweet! So you guys like my work?
Old 07-16-2005, 05:51 PM
Diverbill45's Avatar
Diverbill45 Diverbill45 is offline
Member Emeritus 1945 - 2014
I hope that the person that welded that hasn't quit their daytime job, because if I had ever had someone who worked for me, try to put out something like that, he would have needed his other job. I'm surprised that the customer even accepted that.
It's like anything else, a few bad apples make it rough for the rest of us. Hopefully, with a lot of work and time, there is a welding school that might be able to help this person slightly improve on the skill of welding.
Matt
Guest
Posts: n/a
Well Franz, when I decided to go with the plasma cutter I was thinking that using a pry bar like my boss did could possibly rip chunks out of the base metal, and I didn't want that to happen.
Matt
Old 07-16-2005, 05:56 PM
jpill's Avatar
jpill jpill is offline
And I thought I held the "Turkey Turd" trophy.
