Old 08-04-2018, 05:15 PM
Default Generator Questions?
SWMBO has decreed that we need a backup generator in case of ??? Who am I to argue I'm trying to connive my way into an engine drive welder that will double as a generator. But, if that doesn't fly I'm leaning towards a propane rig due to no worries about stale fuel. First ? At roughly 8000Ft. altitude how much loss/derating should I figure in when looking at specs? Number2 question since our most likely power outage scenario would involve winter winds. How much does low temps affect a propane genset? Number 3 does anyone build an 1800RPM propane genset? Thanks
Old 08-04-2018, 05:37 PM
Just notes.
The run of the mill Generators have to run at a preset RPM to keep proper frequency.
Guessing ???
I would think Some inverter generators may output proper frequency at most any RPM. thus a fuel saving.
Other thing you have to consider is how many gal/hr the generator burns.
fuel storage tank size for days of operation.
For day and sunlight think solar generator.
Old 08-04-2018, 05:42 PM
SmokinDodge's Avatar
No one builds a 1,800 home stand by generator that I know of. Even Onan who dang near only builds 1,800 rpm gensets builds 3,600 home stand by units. I wouldn’t sweat it much, if the enclosure is properly designed you won’t hear it.
Chumly has a standby unit about like what your looking at.
What ever you get excersise it regularly and arm it with mouse poison.
Old 08-04-2018, 05:50 PM
I asked about 1800 RPM gens cause I know they would last longer in long term use. I'm not even sure what triggered the Old lady on this. But, I'm not opposed to the idea at all. If I had my druthers I'd be putting together a Listeroid genset like Gerry has. A prepper mentality is not a bad thing in my mind. Oh, SD I wasn't worried about noise I'm better than 1/2 deaf we could run a 6-71 genset with a straight pipe and it wouldn't bother me.
Old 08-04-2018, 07:38 PM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
Look at the MEP 002 and 003 military diesel generators. Built to the gold standard with your tax dollars. 1800 rpm . Multiple voltages including three phase. I found one on Craigslist with seven hours on the meter.
Klaatu barada nikto
Old 08-04-2018, 08:04 PM
1800 rpm gensets
You did not say anything about KW, but 5-6 should be plenty.
https://www.whisperpower.com/US/4/5/...(low-rpm).html
https://www.electricgeneratorsdirect...enerators.html
http://www.hardydiesel.com/kubota-ge...bota-7-kw.html
Not 1800 but cheap
https://www.surpluscenter.com/Electr...tor-6-1017.axd
Aaron Neville
Old 08-04-2018, 08:57 PM
Check into Generac also. I thought I heard they are offering a 10 yr warranty at the moment. That is one of the popular brands around here.
Old 08-04-2018, 11:08 PM
randydupree's Avatar
Why, Hell Yes!
if you want to go diesel,i have a 12.5 Powertech with 700 hours on it,it was in a wanderlodge motorhome that was wrecked,its in a quiet box,its a 4 cylinder yanmar.
230volt,single phase.
$6000
1800 rpms too.
Old 08-05-2018, 05:32 AM
tnmike's Avatar
Sultan of Scrounge
https://cosprings.craigslist.org/hvo...650626513.html
Klaatu barada nikto
Old 08-05-2018, 09:35 AM
Why, Hell Yes!
Originally Posted by tnmike View Post
thats going to be an air cooled Onan engine,i have one that ran my 3 phase stuff for 20 years,on LPG.
Those engines came as diesel,LPG or gas.
Mine was awesome.
