Old 02-04-2019, 05:40 PM
Originally Posted by Barn Owl View Post
The Hougen cutters I found on Amazon last week that were 2.375" were around $300! The one that Dan found is the "cheap" version at $158.00, but they were the correct size. I have only three holes to bore but the thickness is what is going to tax the cutter.
If you go with a carbide it will not tax the cutter near as much, just your wallet.
Harry S. Truman
Old 02-04-2019, 06:57 PM
You'll learn about Amazon.....someday. Deduct 30+ percent for American price.
Canada Machine Shop
$128 Canadian
$177 Canadian
Aaron Neville
Old 02-04-2019, 10:10 PM
Default Boring a 2.5 hole with a Hougen mag drill
I’m not sure I agree with this statement. Carbide will definitely last longer, but it usually does not get as sharp as high speed steel. Usually you need to feed it harder because it likes to be bogged down. But needs more horsepower to keep up.
I am applying my knowledge from using carbide tooling on the lathe to this situation, so I might be wrong.
Now, I have not used a carbide tipped annular cutter. We only used regular high speed steel ones. I have been known to hand sharpen them up to keep them cutting when needed too. They work the best when all teeth are cutting at the same time, but they will still cut if you only have one tooth cutting. One sharp tooth outdoes 8 dull ones any day, no matter what my boss thought.
Old 02-05-2019, 02:34 AM
I bought mine off amazon prime I'd have to look at the price on my purchased items on amazon but if, I can remember my password... It was a cheapy carbide annulated cutter and I want to say it was only 128.00 or 138.00 bucks.
I am happy with the results from using it... just be sure to be generous with the cooling cutting fluid I got a gallon of that cool-blu and its supposed to make 40 gallons of cooling fluid when diluted it was 40 bucks at the local tooling supplier here
but I do believe when you look at the offers on amazon if you buy this add somewhere on the page for this much type offer just below the pics of the cutter is other offers to sweeten the purchases and the cutting fluid as well just a different brand I think...
Old 02-05-2019, 10:12 AM
camdigger's Avatar
Roving Reporter
I've been tempted for a long time to make a shopbuild line boring setup. In fact, I have a prototype based on a 1" bar laying around the shop waiting on inspiration on a feed/ drive mechanism to strike.
Kieth Fenner has a couple of line boring videos on shopmade rigups that use spherical seat self aligning bearings. Doesn't help that the local discount store (Princess Auto) puts those bearings on sale for less than 15$ each for sizes up to 1"....
The main advantage is cost. A 3$ 1/4" x 2 1/2" HSS blank will bore any size from the bar size to 4". Speeds, feeds, and cutting oils might be issues.
Old 02-05-2019, 11:10 AM
My concern with a 2.5" but would be rpm. I have a Chinese mag drill with a 500 rpm, and I think it is too fast for a larger bit. But if patience and cutting fluid are applied it can be done.
I bought some of the larger rotabroaches, and a MT#3 adapter, so I can use them in the gearhead drill press and in the tailstock of the lathe. I can see a reduction in boring bar time.
Aaron Neville
Old 02-05-2019, 11:13 AM
I’ve seen and used a couple home brew setups Cam, a common way is to use a mag drill to power it, and carefully hand feed it.
For a lot of high end portable machining check out https://www.climaxportable.com/
Old 02-10-2019, 09:46 PM
racer-john racer-john is offline
Gerry, thanks for the tip re: Canada Machine Shop.
They were not showing up on my radar, and they are not far from me.
Tks again.
Lathe Grizzly 9 x 19, Century 110V Mig welder, O/A welder, hammers, dollies, 10 speed Drill Press, multi drills grinders, both corded and battery.
Old 02-10-2019, 11:25 PM
...My concern with a 2.5" but would be rpm. I have a Chinese mag drill with a 500 rpm, and I think it is too fast for a larger bit...
Recommended RPM range for a 2-1/2" rotabroach would be 125-150. I would run it even slower. We have used rotabroaches for years--I know I have some that are 30+ years old and still going strong--and the one thing we figured out a long time ago is that slower is better. They still make holes pretty fast but they also last a lot longer.
...I can see a reduction in boring bar time...
I use them all the time in the milling machine and the lathe--they're a huge timesaver. Any time I can make a hole with a rotabroach that's the way to go. For many things you don't need to touch the hole afterwards. At one time we had them up to 3-1/4" but the bigger ones all seem to have disappeared...
Old 02-11-2019, 12:13 AM
Scott V's Avatar
Scott V Scott V is offline
They are around.. I use Nitto Kohki cutters in my auto feed mag drill, but it stops at 1-3/8 inch X 2 inch
I have been using the Carbide in this brand for my Mill.. Excellent too ,3 inch depth mostly
https://www.amazon.com/dp/B0016JBITQ...lig_dp_it&th=1
