Old 02-04-2019, 11:54 AM
Barn Owl's Avatar
Barn Owl Barn Owl is offline
Default Boring a 2.5 hole with a Hougen mag drill
Over in the Fabrication forum I have been building an iron worker from the ground up. The main pivot axle is 2.5" diameter bore through the 1.5" steel frame and arm. The largest annular cutter I can find is a 2.375". I believe a 2.5 would fit in the drill without hitting the frame but I am not sure they make them that big. Each side plate of the frame weighs 500 pounds and it is difficult to move to a shop with bigger equipment and I really want to do it in my shop. How do I bore the last .125? I have seen line boring rigs for mag drills that utilize pilot bearings but the system alone cost more than the steel. Do you guys know if they make a 2.5" angular cutter for the Hougen with a .75" shaft?
Mike
Thomas Jefferson
Old 02-04-2019, 12:14 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Unhappy
Mike, Amazon has some 2-1/2" × 2"
I searched "annular cutter 2 1/2 "
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 02-04-2019, 01:03 PM
Barn Owl's Avatar
Really! I have only been able to find 2.375 on Amazon. Can you attach the link to the Amazon page?
Mike
Thomas Jefferson
Old 02-04-2019, 01:26 PM
Is this what you were looking for?
Harry S. Truman
Old 02-04-2019, 01:32 PM
Barn Owl's Avatar
Never mind I just found it on Amazon. Some reason on my home computer the search did not find it, but on my phone it went right to it.
Mike
Thomas Jefferson
Old 02-04-2019, 01:43 PM
Lu47Dan's Avatar
Still have not figured how to do links on the smart phone, yet.
Dan.
Hobart 175 Mig
Craftsman O/A set
Old 02-04-2019, 03:03 PM
By the way, I have the cutter size your looking for, I had to buy one, don't spend more than you really need to... buy the cheap one it works as well as the higher priced ones just use cooling/cutting fluid and was what I did for 11 holes and it is still nice and sharp that was drilling through 1/2" plate
Old 02-04-2019, 04:17 PM
JBFab JBFab is offline
... buy the cheap one it works as well as the higher priced ones...
If you are only drilling a handful of holes, fine go with a "cheap" hss cutter. If you have a number of holes to cut, need to drill thick material, or like to buy high quality tools buy the "higher priced" carbide tipped cutters. You typically get what you pay for in this case - it's not a conspiracy against your wallet.
Yes, use coolant unless you enjoy throwing fist fulls of cash away, in which case throw it this way!
Apply a steady feed at a rate your drill can handle.
Sent from my XT1650 using ShopFloorTalk mobile app
Old 02-04-2019, 05:00 PM
I have both German made and chap carbide annulated cutters I just suggested the cheap one I that size if just the couple of so holes and coolant and it will do the job and then some... I just bought the cheap one in that size he needs for 11 holes in half-inch plate slow feed and coolant works
Old 02-04-2019, 05:25 PM
Barn Owl's Avatar
The Hougen cutters I found on Amazon last week that were 2.375" were around $300! The one that Dan found is the "cheap" version at $158.00, but they were the correct size. I have only three holes to bore but the thickness is what is going to tax the cutter.
Mike
Thomas Jefferson
