Old 08-24-2006, 06:32 PM
ND Teacher ND Teacher is offline
Default Lincoln 255c trouble?
I bought a lincoln 255c new in march. It worked great until about july and I had trouble with the wire welding itself to the tip. Not a bit problem but it got worse up 40 times in one day. I tried new tips,new wire, (old stuff was rusty in 4 months) and adjusted the wire and voltage etc. I took it into the dealer they checked the swithc board, put a new liner in, and a new nozzle. It seemed to work alot better. I drug it out yesterday and it wasn't welding right. It acted as if it wasn't getting enough wire. Which was odd because i went by the chart before and it welded perfect. So i turned the wire speed up and it would weld alright and then gasp for wire. It keeps surging as i try to weld. I had a hell of a time convincing the people at the dealer acted as if i didnt know how to weld. I laughed and got pissed off and said I have a L-tec mig at the school that is over 16 years old and I have never had this much trouble and this welder is only 4 months old. I do know I am about out of gas, I know that would make poor welds(porosity) But they will usually weld consistent. I am confused and feel ripped off.
Help
ND Teacher
Old 08-24-2006, 07:51 PM
stseely stseely is offline
I would look at the drive rolls when it is trying to feed the wire. Are they slipping or is the drive motor actually surging? Get it fixed and sell it.
Millermatic 251
Millermatic 135 (sold)
Miller Cutmate 375 plasma
Miller DialarcHF 250 AC/DC Tig/stick
Victor O/A
Optrel Satelite hood
B2 Beverly Shear
Old 08-24-2006, 07:53 PM
Scott V's Avatar
Scott V Scott V is offline
I would get on the horn to Lincoln. If those guys can't fix it, make
Lincoln find somebody that can.
Old 08-24-2006, 08:04 PM
Or return it and buy blue... Yep, I had to go there....
Old 08-24-2006, 08:09 PM
Originally Posted by KB Fabrications
Hey Ron, does that mean you will soon be parting with the red beast in your shop. :evil:
Whudda you think????
Old 08-24-2006, 08:26 PM
Scott V's Avatar
Since he had such good luck with L-tec he should buy Yellow!!!
I think the red 255c is better then the blue one,when it works.
Name:	Esab Thermal pull gun.jpg
Old 08-24-2006, 09:34 PM
....when it works.
Scott are you practicing to go into politics???
Old 08-24-2006, 09:35 PM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
It can also get rust from that dirty wire up in the diffuser and drag on the wire.
Old 08-24-2006, 10:06 PM
fatfrank fatfrank is offline
Pit Boss
Sounds like a liner/tip/wire problem. Sometimes the liner can get kinked witout you knowing, or have wire that is rusty/dirty etc. If it is consistantly bad, I would switch the tip, liner, and check the wire for debris and think of putting on a new spool of a different brand of wire. If the problem persists take it back to the shop and throw a fit.
I have found that changing every thing from the drive roll forward usually solves all my feeding problems. I have been wanting to get one of the wire cleaners I saw BigRig post, but I haven't run across one yet.
Old 08-24-2006, 10:42 PM
They put a new liner in it a new tip, we switched brands of wire, I maybe ran 30 minutes since it was fixed it did good and I put it away for two months and it is acting up again.
This bothers me
