Old 09-21-2016, 02:59 PM
Looks like you need a large shoulder.
http://www.jacobschuck.com/drill-chuck-removal-guide
Good link Wiz.
Tackit, you don't have a shoulder, so you can not use wedges to remove it.
From the link above.
In case the mounting taper of the arbor does not provide a shoulder, a cross hole should be drilled through the neck of the arbor (illus. D.) and a cross pin inserted. Then the wedges can be used between the chuck back and the cross pin. If desired, a hole may be drilled through the soft center portion of the chuck body (Illus. D.), and a pin may then be used with an arbor press to force the arbor out of the chuck.
See the link for the pictures. Personally I would do the second option and
drill a pilot hole through the center of the chuck and drive the arbor out.
Old 09-21-2016, 05:23 PM
Personally I would do the second option and drill a pilot hole through the center of the chuck and drive the arbor out.
That's what I had to do to get the old MT4/JT5 arbor out of if my Jacobs 30N.
It really isn't difficult to do & doesn't hurt the chuck.
Once you drill through the top of the chuck the arbor should pop right out with a punch.
Old 09-21-2016, 06:05 PM
tackit's Avatar
tackit tackit is offline
Thanks fellas, I learn something new everyday around here. OK, tomorrow I'll drill a hole down the center of the chuck and use a suitable size pin punch to force the arbor out. My hip went out this afternoon or I would have done it already. I must have been sitting on it wrong again, it feels like a nail gun shot to the hip when I get up from the chair or move a certain way.
Old 09-21-2016, 06:29 PM
Randyjaco's Avatar
I made my own out of CRS. They have worked fine for several chucks.
Randy
"There are three and only three ways to reform our Congressional legislation, familiarly called, the ballot box, the jury box, and the cartridge box" (Frederick Douglass)
Old 09-21-2016, 07:08 PM
tackit's Avatar
Randy I was tempted to open up the #2 wedges on the mill to fit my arbor, but after learning my chuck doesn't have a proper shoulder to use wedges I'm going to pass on the idea.
Old 09-21-2016, 10:50 PM
It is the arbor that needs the shoulder.
Old 09-22-2016, 06:39 AM
Check the size 6 . The numbers DON'T go by size. We have a "set" of 1,2,3,6 at school and the number has nothing to do with the size. :-)
...lew...
Old 09-22-2016, 06:46 PM
Randyjaco's Avatar
Okay then, how about opening up the chuck jaws and drill a 1/4 "-5/16" hole through the bottom of the chuck. Then with an appropriate drift press or hammer out the arbor. A little Kroll or penetrating oil wouldn't hurt. Should have no negative effect on the chuck.
Randy
