Old 10-21-2018, 09:28 AM
Default TIG Brazing anyone still use this and why
TIG Brazing.....anyone use this type of weld/Brazing and what application would or have you use it for
been a good while since I've use the "crib" brazing rod and noticed that some of the LWS don't carry the filler rod and as I remember you can not use normal brazing rod.
Old 10-21-2018, 11:21 AM
Gadgeteer's Avatar
I patched up this wrought iron(?) wedding arbor for a neighbor a few years ago. He leaned it against his garage, and the wind toppled it over. A few dozen small pieces jumped off. Tigged back together with silicon bronze filler. Sorta like trying to solve a crossword puzzle; from across the street, nobody knows if a piece is out of place.
Name:	Welding Arbor.jpg
Old 10-21-2018, 12:25 PM
We have several different brazing rods at the shop--have to look and see what they actually are. The most common will be silicon bronzes but I know there are some other options. There are some specialty rods that are $7.00-$8.00 per rod--pricey but they work for the right applications. All of them get used with the tig torch at one time or another but some can also be used with oxy-acetylene. Our LWS has a good selection...
Old 10-21-2018, 01:45 PM
Ritothebull Ritothebull is offline
I tig braze on cast iron whenever I think I can get away without pre and post heating larger parts because it's just too damn hot down here to be heating stuff up. I did some copper to brass parts last week with some 5% sil-braze rod that were previously soldered and had failed.
RTB
Old 10-21-2018, 02:18 PM
I have not done it for 30 years, so no real time advice here. I liked it mostly for the appearance way back then. I am so old that I remember doing electroslag welding and O/A welding with clothes hangers.
Old 10-21-2018, 03:45 PM
Gadgeteer's Avatar
Dang, that's old!
I remember using bailing wire to O/A weld my first recumbent bike frame out of electrical conduit.
Old 10-21-2018, 04:12 PM
Wolfram's Avatar
Wolfram Wolfram is offline
I braze and braze-weld with silicon bronze filler, but I usually use O/A for heat instead of tig. Seems like I have more control that way, and it's easier to heat the surrounding material with gas than tig, iMHO.
I dip it into 20 Mule Team Borax, and often sprinkle some borax on the work (the dirtier it is, the more borax I use) as a flux. Works well. I often use this for CI repairs, thin metals, things I don't want to distort by welding, and things that don't need to be super strong (though it approaches weld strength). The nice thing about it is that it's like glue, and you can undo and re-do it if need be without messing up the work.
Only major downside is that you need to chip off the molten borax, which almost forms a glass coating, before painting. If it's hard to chip it all off, I'll soak it in water, as well, which helps dissolve the borax.
Old 10-21-2018, 05:59 PM
I see it done for large copper buss bars, where there is no way to weld.
(too much copper, would suck the heat right out)
Old 10-21-2018, 10:26 PM
Ok I was going to TIG some SS to carbon steel using this method for a client project
Old 10-22-2018, 03:10 PM
Off topic a bit, but when welding heavy copper sections (1/2x12) we preheat with propylene to at least 500F, use AWS A5.7 ER Cu 0.045 dia. wire and run the wire thru a liquid cooled mig gun. The shielding gas is a special trimix, .5% H, 37.5% Ar, 62% He. It's not the prettiest weld, but it does hold together. Gearing up for a job next month, so these numbers are fresh in my mind.
