Old 04-04-2024, 11:47 PM
Default What Is It?
My dad had some of the coolest tools. Case in point, rewiring the mill today with a new cord.
So, what is it?
ID:	170521   Click image for larger version
Old 04-05-2024, 12:00 AM
Screw starter.
you left out the details.
note the center smaller blade position, outer blade is spring loaded so it keeps rotational tension in the screw slot.
Old 04-05-2024, 12:09 AM
That didn't take long...
Lisle No. 4788
Old 04-05-2024, 05:26 AM
So, what is it?
My dad had two of those as well, and I think I ended up with them. (He used to use them mostly when changing points and condensers in distributors.)
I remember fiddling with them as a kid.
Old 04-05-2024, 05:47 AM
My dad had a couple snap on ones. One was a Phillip head too. Think I still have them, plus a couple more I picked up over the years.
I also have a different style that has two angle tips that as you push a tube out the shaft slide the ends together that makes the tip wider and grips the slot that way.
Old 04-05-2024, 07:31 AM
I also have one, they were and still are handy when setting points in a distributor
Old 04-05-2024, 08:05 AM
astronut's Avatar
astronut astronut is offline
I have one as well in my tool chest. Havent seen it in awhile since I havent had a need for it in a good while.
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 04-05-2024, 08:57 AM
Twice the size--half the man
Got a couple myself, though I can't say that I've ever used them. They've been in the top-middle box of his old Mac chest as long as I can remember.
Things in that drawer were always his most precious and obscure. It also has packages of replacement glass cutting wheels and divider scribe tips. There are lots of other small oddities in there. I was always encouraged to use whatever tools were available but anything in there was off-limits unless I was specifically instructed to find the item.
Wade's Custom Kydex
Old 04-15-2024, 07:26 AM
I had a similar one with a plastic handle I carried in my electricians pouch for holing the screws to start when putting on the receptical covers. Those little oval head screws are a bugger to hold. :-) But like the rest of those tools and the pouch it went, when some jerk broke the door window of my car and made off with it a few years ago. :-(
...lew...
