  #41
Old 04-10-2024, 06:56 PM
Depends a lot on soil .Around here so many rocks the direct burial stuff tends to get insulation issues and prone to failure .
  #42
Old 04-10-2024, 08:44 PM
Norcal Norcal is offline
Originally Posted by gimpyrobb View Post
Duke installed my power pole today! Now I need to look into renting a trencher and some power cable. Do I need to run conduit from point to point or do I just use conduit where it enters/leaves the ground?
I used to say that conduit was cheap insurance but bidenflation has made PVC conduit way more expensive then it was, but conduit is still wise unless you bury the cables in sand I would still pipe it.
  #43
Old 04-11-2024, 10:03 AM
What’s the code/utility company say?
I know in Onterrible the one job I did it all had to be in conduit. Another it was just the ends. Both had to be I think minimum 3’, but with labelled ribbon 12-18” above them.
  #44
Old 04-11-2024, 07:53 PM
I like to use Teck 90 armoured cable. Good for under ground, under water, anything. Your regs may vary. All power to my shop and house right from the pole is done with Teck 90 3/0 and 1/0
  #45
Old 04-11-2024, 08:36 PM
gimpyrobb's Avatar
Meter boxes showed up today and I picked up 120ft of 4ot cable for 325!
  #46
Old 04-11-2024, 08:38 PM
Teck is not used in the US, & the equivalent MC cable is mind numbingly expensive, as are the fittings.
  #47
Old 04-12-2024, 09:34 AM
That surprises me, but it is the way it is.
Waterproof Teck connectors are 50 buck each but the cable, because it is so common in industry is available used for cheap. At a scrapper's, I bought a roll of #1 teck un-used and never had the paper cover off the wooden reel, 830 ft for 1100 bucks, price of scrap copper.
  #48
Old 04-12-2024, 07:49 PM
gimpyrobb's Avatar
I never thought I'd pay more for conduit than for service cable!
565.59 and an hour drive one way for the conduit. $325 for 122ft of 4ot aluminum service cable. The cable was surplus from a job an electrician did, it was an hour drive too. The conduit was $10 cheaper per 10ft secti9n than anywhere else, I needed 12 and they had 10.
I also got my permits today. 180 for those. I called the inspector to verify depth, 18inches to the top minimum. He also said nec rules change Monday and there are a lot of changes! The rules go by the permit date so it seems I REALLY dodged a bullet.
  #49
Old 04-13-2024, 09:18 AM
One thing that you can probably count on is the rules change will not be cheaper to install.
  #50
Old 04-14-2024, 07:57 AM
gimpyrobb's Avatar
So, quick tally, I'm calling it $2k so far. 2 panels, 2 stereo boxes, 2 permits, some service cable, pallet jack to move things, and fuel(I'm adding $76).
