  #31
Old 10-08-2021, 05:45 AM
CaddmannQ's Avatar
Pics of my VW project car. This is fiberglass, so not rusty, but the frame below is Swiss cheese.
ID:	161851   Click image for larger version
ID:	161852   Click image for larger version
  #32
Old 10-14-2021, 12:34 AM
CaddmannQ's Avatar
I got a chance to try my fancy new helmet yesterday, when I welded up this worn out hook from the clutch pedal on my car. I remember breaking one of these off of my 1966 type three fast back, and having to do a trooper start and drive across town with no clutch. I was very careful to inspect this hook for damage and it was certainly worn.
I tried to start with 100 A and almost melted the thing off onto the floor, as it is only about 1/4” x 1/8 at the worn section. I stuck the tungsten in the puddle four times and had to stop and grind it.
I was trying to lay the filler right in the groove and start the arc on top of everything at once, but it didn’t quite work that way. At 100 A the arc ignored my filler completely and tried to melt the hook right off.
I increased the stick out and the gas and turned down the heat to 55 A.
At that point I was able to dab some filler in the hole and close it up. After some grinding and filing it was serviceable again.
ID:	161990   Click image for larger version
ID:	161991   Click image for larger version
  #33
Old 11-01-2021, 01:30 PM
CaddmannQ's Avatar
The biggest thing that my test welds have proved to me is that I would like more practice time before I start laying metal on the car.
My daughter brought me a broken steel bed canopy and headboard, and so I am practicing my light gauge TIG welding. Holy cow, this stuff is thin! I only blew through six times in 32 welds.
But this was a good thing for me because it pointed out the fact that I needed some practice to weld this submillimeter material. Fortunately this gave me a lot of practice doing small welds on corners and seams and edges, inside fillets, and welds from round to squares sections as well.
By the end of the process I could tell that I had improved my technique and control but also I was getting tired by then. I will get some more practice and then I expect to have good results on the chassis when I get around to the major welding. Also I think I’m going to be glad that this machine will do a good stick weld, Because there is some 0.188” & 0.145” steel that I intend to join with some tapered slugs made from 0.375x1.5” bar.
That’s gonna suck up a lot of heat for my little number 17 torch.
So I’m trying to decide if I wanna buy a big torch or just stick weld the thick sections. At this point I have more stick welding experience than TIG. I already bought some stick welding rods. My biggest problem is that if I’m using a stick welder I’m gonna want a fireman standing by. I don’t wanna burn this place down and I will likely have to do the stick welding outside if I am by myself.
  #34
Old 11-02-2021, 01:43 PM
Do I have a life?
I keep a 5gal pail filled with water near the welder. I keep a lid on it so the skeeters don't develop an interest in it. Perhaps have the wife keep fire watch?
I PM'd you about the torch below. In addition to the Weldcraft HP-26 torch handle, you'll need something like this LINK. You would cut the lug off and put a Dinse end on it. Note this is a 2-piece, 25'. The part # is 46V30-2, without the -2 is 1-piece but you'll need a power/gas adapter at the machine. 46V28R is 12' 1-piece version, "R" means rubber.
ID:	162411   Click image for larger version
ID:	162412   Click image for larger version
HF 80 lunchbox w/tig
  #35
Old 11-02-2021, 02:45 PM
CaddmannQ's Avatar
Thank you buddy. I’m not familiar with that gear but it’s probably an excellent price.
I’m afraid that I’ve blown all my fun money between now and the new year.
I got to pay taxes and buy presents for grandkids and all that stuff before I think about myself again.
In any event, I won’t be getting around to that heavy gauge welding until I take the whole car apart again. For that to happen it’s got to get a title. If I can’t get it titled I’m just gonna take it to Nevada and sell it off at the car auction.
  #36
Old 12-07-2021, 06:53 PM
Avmech Avmech is offline
Another with the PrimeWeld Tig 225, got it about 6 months ago. So far very pleased with it. Used to use Millers and Hobarts close to 40 years ago…….
Running mine with the water cooler and a CK20 torch. Used it on 110 early on before I added a 220/50 amp outlet, now it is way happier with the 220v.
Getting ready to do some body repairs on my old truck so I just got a TIG Button last week to use in place of the foot pedal for out of position. Used it a little already, way better than the plain on/off switch on the torch and better than the variable amperage knobs/switches/whatever that are in use. This thing increases amperage the more you press on it.
  #37
Old 12-08-2021, 12:37 AM
CaddmannQ's Avatar
I am really loving the Primeweld. I have not yet scratched the surface of what this welder is capable of and yet I am already glad I spent every penny on it.
I would definitely like to get a larger water cooled torch for certain operations but in the meantime I will be able to get by with stick welding and the 100 amp CK-17 torch.
But sometimes you just gotta have an oxygen torch.
The car I am working on should’ve had two left hand seat rails and two right hand seat rails, but it was supplied with four left-hand rails.
These were 16 gauge sheet-metal Z shapes and they were tapered so the seat would lean back slightly. I had to reverse the bends on two of them, and I did it by anealing the creased sheet metal and knocking it flat on an anvil and then clamping it down and heating the edge as I rolled it over with a hammer.
OK, in the end they look like hand-wrought iron now, but they are under the seat where nobody can see them, and my seat is not sticking out the door.
LOL
  #38
Old 12-08-2021, 08:38 AM
The CK 20 is smaller than the 17 and handles 250 amps. And fully agree the machine is way more capable than I am currently. When I learned TIG many moons ago (1973ish), we had no pulse, adjustable freq, 2T/4T, etc. It was amps, post flow, DC straight/reverse/AC, 2% thoriated and balling the electrode using DC reverse for a second for aluminum. And yes the oxy-acetylene rig is right next to the TIG welder. And good work on the seat rails!! Love it when someone just plain figures out a way to do things and does them!!
  #39
Old 12-09-2021, 02:06 AM
CaddmannQ's Avatar
Thank you. I actually did the other seat rail by welding instead. I cut a pie slice out and rewelded it backwards. It took about the same time, but lots of weld draw meantsome post processing with a hammer and anvil.
Tags
tig
