My father bought 30 of those Westinghouse generators when a nearby airbase closed following WWII. He told me he built ten welders over the years, all trailer mounted, and still had one of them parked on a vacant lot across the street from his house when he died. It was powered by a little 4 cylinder water-cooled tractor engine. I had a brief impulse to try to save it but the tires were rotting & I had no place to store it at the time, etc. He used those welders mainly to weld casing on irrigation wells & had grown to prefer them to any other welder for that purpose, probably because that's how he learned to do it in the first place when he started drilling wells in about 1950. He drilled the first irrigation well in Hardeman county Texas and his second one was in the farm where I grew up. He had 2 of the generators out in his shop when he died and I still have the one I brought home with me about 25 years ago. As Gerry said, I do remember they required at least three stout belts, 4 is better. If I recall correctly, Dad used 5-6 inch diameter pulleys to get enough belt wrap to maintain "traction". Looks like you have yourself a fun project there but I agree that you'll need to upgrade your pulley & belt configuration to make it work correctly.
Chris, I suspect you're going to need more horsepower than that.
15hp??????
Chris, I don't really know any more than I "think" I recall from my dad's experience but I believe he never used less than 20-25 hp. They were all 4 cylinder engines. He had one generator rigged to quick mount to his little homemade tractor that we called the Doodlebug, powered by a military surplus Jeep engine. The generator was a rear mount & ran off the power takeoff.
I can remember seeing him use it & that little engine would lug noticeably when that arc kicked in. I mean I could hear the governor kick in. I have very little experience with gennys but I do have a Briggs/Generac in the shop, I think it's an 8000 watt, 13,500 "starting watts" with a 15hp Briggs on it. The generator on it is nowhere near the beast that one of these old Westinghouse units is. If I was in the mood to build my own welder I would not be comfortable with the notion of using a lawnmower engine. I'm sure Gerry can tell you more definitely what's required.
The 25 hp requirement may be about right. Dad said that, before our farm got REA, Grandpa had one of those generators with brackets to mount on our B John Deere tractor and ran off the belt pulley. Rated at 33 hp, on the belt, Dad said my uncle could really get that tractor to talkin' when welding heavy stuff.
RIP Cutter |
And I agree with the others that 15 HP ain't gonna be enough. I can't recall seeing one of those things that wasn't powered by a 4 cyl. engine. Stepping up to 25 HP will probably be enough--Guru Gerry will know for sure...
28 volts x 300 amps = 8400 watts
you will get about 450 watts per gasoline horsepower so 18 hp is the minimum requirement. On a welder more is better. A lag in response or an rpm drop means your arc will be unstable and stick. That V4 is about right. Take the popular old Lincoln Pipeliner producing 200 amps from 35 horse Red Seal engine. Way overkill? No, The excess hp makes it rock stable and the current output unstoppable. The other thing that demands power here is the belt ratio. You need some balls to drive up a mountain in high gear, and that is what you are doing by gearing up 1000 rpm higher then the engine. That gearing sucks up engine torque.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
Looking like an old Jeep 4 cylinder may be the ticket.
Or flat belt off your M.
Sent from my ipotato
The guy that said money can't buy happiness never bought a tank of fuel for a turbo diesel............. |
Cutter, sorry about the photos. I did read the faq, but then I clicked insert and it allowed me. I missed the part about uploading from Manage attachments. Thanks for fixing it up.
I fired the unit up yesterday and checked for belt slippage. ...no load and it slipped so off to find proper belts tomorrow. I made up some bolts to push the unit back for tensioning. I also checked voltages. ..around 28 -30 no load so it is in line with what has been mentioned. Thanks and I will report back when new belts are installed. Cheers |
Tags |
old welder, vf4, wisconsin |
