SFT Search: |
Thread Tools | Display Modes |
#81
Look at the picture in this e-bay link, the back ground you see a magnified rolled up endless chip guessing 3/32" wide. Its a pair of scissors that makes a 3/32 wide cut (it does not snip off the chip with each nibble)" http://www.ebay.com/itm/Precision-Ha...#ht_1437wt_736
#82
#83
As for backing a piece of oak wood, the thicker the better. As for grinding the width of the chisels, don't grind the full side length, the depth is less then 1/16" so that is all you need
#84
Not exactly what the OP wants to know for this current project. By chance I came across this on You Tube. Some may find it interesting. Once on You Tube it leads to other videos and another one of them is 'Drilling a square hole' Look here: http://www.youtube.com/watch?v=7n1r5XfVkyk
Al |
#85
http://www.buybroaches.com/How-Broac...orks_ep_7.html would love to use that, but too expensive: $50 bucks for a broach, plus $750 for a broach holder, plus the lathe, mill, or CNC machine to mount it on. Making it prolly the single most expensive option in this thread (that said, i bet some DIY'er will someday DIY a hand-driven wobble broach for a fraction of the cost! But it won't be me) For this project, i'm going for a very low-cost manual method, suitable for our youth fabricators (and suitable for our minimal non-profit budget). it looks like i am closing in on a method to cut any size/shape hole in aluminum, clean and burrless, with a tool costing about $10, including blades. Just waiting for the blades to be delivered. i will post the results here. thanks! Last edited by johnyradio; 12-31-2013 at 04:58 PM. |
#86
An actual, honest-to-God D-sub punch would be the most idiot-proof, quickest and easiest way - but you're right, there's no way you're gonna do that for 10 bucks a pop. Best I can offer is good luck... Steve
(We all get stuck in that infamous triangle - the "good, fast, cheap" one - pick ANY TWO, you can NEVER have ALL THREE ) |
#87
You'll see the solution we're moving toward. |
#88
the .028 spiral coping blades arrived, and they provide greater control and tighter turns than the .040 blade.
Later when i get the same .028 blades made for a jeweler's saw, i expect that will give even better control. As far as i'm concerned, this thread is solved! But would really appreciate these loose ends: The workpiece will be clamped to the edge of a table with a quick clamp. i'm thinking to use some cloth or foam, to prevent the aluminum from getting marred by the clamp. this process does generate metal filings, so i need to work out a setup to safely catch/remove them, keeping in mind that our bench is often temporary, in a classroom or carpeted area. Maybe i can just put a trash bin on the floor under the workpiece. i found that a wet paper towel easily wipes away filings that collect on the workpiece itself. and need to find the best way to smooth the edges. There are no burrs, just a slight roughness to the edge. So i'm guessing a very fine grit, flat-face file, with a handle to protect kids fingers. re the best way to stroke, i found this: "turn my file around and draw it back towards me. I think thats called draw filing and it works really well with the edges of skins. 2-3 pulls, light pressure". i'm looking at the following el cheapo files, but i can't tell their grade. Any thoughts? http://r.ebay.com/vBJkU4 http://www.harborfreight.com/12-piec...-set-4614.html Last edited by johnyradio; 01-12-2014 at 03:14 PM. |
#89
what nibbler make/model did you use for this? the nibbler i tried is so big, i don't think it could do what you show in your pix. It looks like this:
http://r.ebay.com/jCo6JC |
#90
I use a Klein Tools Nibbler
Klein Tools 76011B Nibbler Tool http://www.amazon.com/Klein-Tools-76...ywords=nibbler |
Tags |
aluminum, cut, drill, punch, sheet |
