Old 05-22-2020, 08:58 PM
Default First Fab Project In Ages
Over the last couple days I started on a project for SWMBO. It's something I wanted to knock out for awhile. But, various bits never lined up. This time of year my hours are usually between 48-55 hrs. Not so during the Covid Shit-Show. Which is a double edged sword.Time and energy to work but limited resources I got off work at 10:30 on a Fri. Memorial Day Weekend So, I finally am not exhausted come Fri. But, money is a little tight. So, Mama's project is going to utilize a lot of resources from the "Pile-O -Stuff" Most of today was spent creating angle iron from Chinee bed rails. Which should work out fine unless I actually need to make a hole in it. Which is not planned at this point. Basic mock up layout is happening on the front sidewalk which is the only decent size flat space I have.
ID:	156223   Click image for larger version
Old 05-23-2020, 10:15 AM
Looks like a good start to a raised planter. Your "Pile-O-Stuff" has served admirably.
Old 05-23-2020, 02:13 PM
Default Progress
One side is fit up and tacked
Old 05-23-2020, 04:37 PM
Pondering my next move regarding mounting legs. Triangle mounting plate flat on each corner and weld the square tube legs to the plates or a chunk of 3" channel across the the bottom of each end and legs welded to the channels. It would be major overkill but save me a lot of time. The weather is supposed to take a turn for the worse tomorrow so I'm leaning towards overkill it's past 3:30 already and I'm getting tired and thirsty too.
Old 05-23-2020, 07:32 PM
Got chased in by what looked like real rain of course it blew over by the time the tools were stowed away. Still I made decent progress I need to pull the small channels supporting the barrel halves and drop them down another 1/2". I want the top edge of the barrels below the top of the angle iron frame so I can drop in some boards around the inside of the top edge to clean things up and bring the dirt up more. I ran a few welds before I quit for the day. Man am I rusty looked like they were run by "Blind Melon Chitlin"
Old 05-23-2020, 09:53 PM
Me thinks she will be very pleased.
Old 05-24-2020, 08:19 PM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
I see you're using CAD. Concrete Assisted Design.
I also use CAD. Cardboard Assisted Design.
Dave
