Old 12-15-2021, 09:01 PM
Originally Posted by unfinished View Post
Regarding Fluid film: Well I already bought a couple gallons, some black tinted and some original color, sitting here on the workbench. I'll at least try it and see if it washes off. Does the transtar stuff come in gallon size? $20 for a spray can is bit much. The other option is doing some homemade waxy oil type stuff, with the toilet bowl wax ring, some grease, kerosene or hydraulic oil, whatever your favorite recipe calls for.
The Transtar does a great job, I did my new to me bed and frame aft of the
cab. Use 1 full can and a part can, still using the same part can for odds and
ends. I use it on hub assy and brake rotors all the time and have had them
come off with ease since. So the cans go along way they are big cans.
You can just dissolve the wax and fluidfilm to make your own, you can usually
get cheap paraffin wax at Hobby Lobby. FF is going to give you far superior
Rust Protection than using hydraulic oil or some off the shelf grease.
Old 12-15-2021, 09:06 PM
Ha, what do you have in mind?
If your turbo is working no reason to change it.
I use this product and paid for the Ford package, so I can read and run all the Ford diagnostics. I have the 2000 F-350 and a 2011 Explorer.
I have been very happy with the product. With it I can monitor the boost.
https://www.autoenginuity.com/scantool/
Old 12-15-2021, 09:59 PM
unfinished unfinished is offline
Actually that is the scanner I have. But I havent really taken advantage of it, just reading codes, some buzz tests here and there and taken some instant readings on some sensors. I never really tried driving around and data logging. Part of it is not knowing what the expected sensor values for healthy engine vs one that is a bit worn out but still operating mostly fine.
Sensors i want to watch are?
1) ICP - injection control pressure? this is the oil pressure driving the injectors (ipr modulates this based on computer control?), and will be up to the 3000psi that the hpop puts out? I dont know what pressure numbers to expect)
2) IPR - duty cycle - if i understand right, with a healthy hpop the IPR duty cycle will not exceed something like 60-70% under near WOT. If weak hpop, then duty cycle will run higher in attempt to meet the injector needs.
3) manifold pressure - amount of boost over atmospheric pressure? I can use this to see boost turbo puts out.
Old 12-15-2021, 11:57 PM
If you paid for the full Ford unlock package (it is worth it) looking at any input is easy. If you just have the generic ODBII, not so much.
Old 12-16-2021, 12:06 AM
Yep ford package. Bought long time ago for another truck but did not do the yearly updates, so I think i can only do through 2008 or 2010 model year. Yeah, just overwhelmed with the PIDs I can view, long lists of all sensors.
Old 12-16-2021, 10:45 AM
Grizz Grizz is offline
While you have the engine where you can get at things, I would recommend you change the injector mount o rings, easy job on a bare engine, kind of a bitch in chassis, a seeping hpop oring can cause all manner of fun symptoms, also check and clean the fuel passage return valve,
Old 12-16-2021, 10:54 AM
Sweet, I have been happy with the system.
Old 12-16-2021, 05:40 PM
Injector mount o-rings? could you clarify, not sure what this is. the injectors are coming back rebuilt with new plungers/barrels and new nozzles. And will already have new o-rings (the ones that seat against the injector cups in the head) installed and copper crush washer. I just got to pop out the old injectors and install the new ones. I will take out the GPs so i can evacuate the oil that falls into the cylinders.
Yeah i will clean the top end and look for oil leaks from hpop and lines and pedestal. Not sure where the fuel return valve is, but ill investigate. thanks.
Old 12-16-2021, 07:16 PM
That is the o rings I was talking about, they separate the passages, perhaps I skipped over reading the part where you mentioned having the injection units out. When someone says injector o ring to me that means internal o rings, if applicable, nomenclature, Kind of like rocker covers as opposed to valve covers,
Old 12-16-2021, 08:37 PM
Great, the "mount" part threw me. Plenty of o-rings in this truck, just wanted to make sure. Thanks.
