Old 05-12-2021, 12:10 PM
Default Custom fitting
So as mentioned in my tonneau cover thread, the existing fitting is slightly too high and rubs on the aluminum.
I picked up another 2” NPT hex plug, steel, to start as a base for this.
Today I fired up the welder, and built up a rough rectangular area on top of the plug.
Next step is to get the mill going and start carving.
Old 05-12-2021, 09:32 PM
Find one of the brass low-profile street elbows. Should save you quite a bit of room. That standard steel el you have now is pretty tall...
Old 05-13-2021, 09:45 AM
I did hunt for one at the time, with no luck locally. This version will gain me another 3/4” or so even over the low profile fitting.
Old 05-14-2021, 05:17 PM
First pic is after the first round of welding.
Next is after a bit of time on the mill today.
Old 05-14-2021, 11:04 PM
Finished milling.
Drilled and tapped 3/4”-NPT
Old 05-14-2021, 11:06 PM
Bit of tidy up to deburr it, clean it and squirt a bit of paint and I’ll call it ready to install over the next day or two.
Old 05-15-2021, 07:01 AM
Nice! Did you have any trouble machining it, it looks quite hard.
Old 05-15-2021, 11:05 AM
Nope, pretty much machined same as mild steel. Even drilling the side hole which would be half original, half weld metal, other than chips breaking a little easier, it cut no issue.
Old 05-16-2021, 08:09 AM
Nice. I never thought of doing that.
