Old 05-06-2021, 11:45 PM
Lith74 Lith74 is offline
Default Central machinery complex machine 891 mill parts
Hello, does anyone know where I can get a replacement quill return spring for this machine. I've measured some of it, its about 12mm wide and 1.5mm thick. It's a 1985 model that I got dirt cheap and needs some love.Also saw a thread with the owners manual, I would like to get a copy if someone is willing to share. Thanks.
ID:	160324   Click image for larger version
ID:	160325   Click image for larger version
ID:	160326   Click image for larger version
Old 05-07-2021, 06:58 AM
raulie morse raulie morse is offline
Default quill return
probably not the help you're looking for but I had a drill press with a broken quill spring & I fabbed a small pulley for the handle & routed a cable over another pulley to a weight to return the quill. An old fashion way that was used years ago. FWIW
Old 05-07-2021, 08:05 AM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
See what you can find here....
https://www.amazon.com/s?k=quill+spr...l_300ncmx3bf_b
Old 05-07-2021, 08:26 AM
Try High Quality tools in Cleveland:
http://hqtinc.com/
Old 05-07-2021, 01:24 PM
Thanks for the responses guys. I had already looked on Amazon and Epay (yes I meant to spell it that way) thus they don't seem to have the same measurements as what I have. I wanted to check with the more experienced crew here before trying to find something and trying to make it work. I am leaning towards ordering one from Grizzly for a similar machine. Waiting to see if there is more feedback here before I pull the trigger. Thanks.
Old 05-07-2021, 02:56 PM
Not quite the size
10mm x 1.6
https://www.ebay.com/itm/39225973586....c101195.m1851
select the size
this one has a 12mm x 1.2
https://www.ebay.com/itm/39277035942...oAAOSwv89exOtT
Old 05-08-2021, 06:19 AM
Did you "Ring up" as in talk verbally to HQT ?
The go by size as well as machine brand.
I go to their counter, and actually speak with a human being.
Not much is listed on their website.
Old 05-10-2021, 07:28 PM
Send me an email address, I’ll send you a digital copy of the manual
