Old 04-19-2021, 02:22 PM
Originally Posted by camdigger View Post
not sure how a\localized annealing will work. The material is moderately thick so I am curious if it would be possible to anneal locally without the surrounding metal chill the hot spot...
No way to know for sure until I try it in an hour or so....
Let it cool slowly before drilling.
Old 04-19-2021, 02:45 PM
If it work hardens again while drilling stop, sharpen the drill and repeat the annealing process until the hole is done.
Do not try to drill to size in one step if you are making the hole significantly larger. The idea is to keep the pressure on the cutting edge high enough to maintain cutting without work hardening the spring.
Use good quality bits as nothing will make a bit that is softer than the spring cut.
Old 04-19-2021, 03:12 PM
You can make a starting spot with a Dremal / grinding stone.
Old 04-19-2021, 07:06 PM
camdigger's Avatar
Roving Reporter
Well, after all the anxiety, it was rather anticlimactic.
After cleaning with a flap wheel and grinding the edges with a hand angle grinder, I spotted the holes with a drill guide. Drilled through with a 9/32" pilot bit lubed with threading oil, then to full 1/2" again lubed with threading oil.
It did take more feed pressure than mild steel, but otherwise no big deal. GM springs not all that hard, I guess. Hope it stands up to the job... I can always grind a new face on it and do a localized flame hardening if wear is an issue.
Old 04-19-2021, 08:56 PM
Thumbs up
