Old 03-16-2021, 02:39 PM
tigman250's Avatar
tigman250 tigman250 is offline
The Right Stuff
Send a message via AIM to tigman250 Send a message via MSN to tigman250
Default Okamoto surface grinder help
Good afternoon all, I have a surface grinder that is giving me fits, the table is hydraulically driven and occasionally slows down when moving to the left. It seems to work flawlessly for about an hour in the morning, after that starts acting up so whatever it is seems to be thermally triggered. The manual calls for the pressure to be set at 210 PSI, when it is acting up the pressure drops to 150 psi, if I set the pressure to 175 PSI it goes the same speed both directions just slower than if set higher but doesn't "kick out". So far I have cleaned every single valve and solenoid, changed the pressure relief valve and just put on a new pump. The new relief valve and pump have helped a little bit, before changing them I could only run 125PSI to keep it from kicking out. Seems like a valve is hanging up half way and dumping the pressure but I have swapped the table directional valve with another one from the cross feed, I have swapped solenoid coils around, like stated earlier cleaned all the valves and replaced relief valve and vane pump. Any hydraulic experts out there that can help a brother out? I am almost embarrassed that I can't figure this thing out, it's been kicking my butt for a month now, just replaced the pump yesterday and thought I had it but after a half a day of running it today the operator came and told me it's acting up again.....
Thanks All!
The one that dies with the most tools wins
If it's worth having, it's worth working for
I carry a gun because I'm too young to die and too old to take an ass whoopin!
Old 03-16-2021, 10:49 PM
greywynd greywynd is online now
A resource for you, contact Jim Sellyer at https://harigtechsupport.com/
Harig and Okamoto were affiliated somehow, he knows both makes well.
Old 03-17-2021, 07:49 AM
tigman250's Avatar
The Right Stuff
Thanks Greywynd!!
Old 03-17-2021, 04:16 PM
Hope it helps. We had a few Okamoto’s at the diecasting shop I worked at.
Old 03-27-2021, 12:50 AM
SmokinDodge's Avatar
Check the cylinder and mechanism. Sounds like excessive drag causing heat in the hydraulic system. A temp gun would be an easy way to check stuff before spending money.
