Old 04-12-2021, 08:18 PM
Default Carbide Boring Bar Bar
At the scrap yard I found two boring bars. These bars used insert tools but the bars themselves were made of carbide. Has anyone seen or used one of these?
I am curious to know the advantage of such a bar, perhaps less deflection?
Old 04-12-2021, 08:42 PM
Yes that's it more on the side to stop chatter, only used solid carbide bars not with inserts.
you may also find some that are filled with some type of liquid anything to change the harmonics.
Old 04-13-2021, 10:44 AM
JH35's Avatar
JH35 JH35 is online now
Yes they are much stiffer hence the less deflection.
Curator of the canned cycles.
Old 04-13-2021, 10:45 AM
JH35's Avatar
I have used these also. They seem to work well.
Old 04-14-2021, 09:55 AM
Now that I think about it I suspect the higher mass of carbide over steel will also have a significant impact on harmonics.
Old 04-14-2021, 10:03 AM
JH35's Avatar
Lead is denser than steel too haha. But something to do with hardness and stiffness.
Jeff
Old 04-14-2021, 10:04 PM
Jeff
That's what she said!!!
Old 04-16-2021, 07:35 AM
If they are in the scrap bin because of a damaged or "blown" pocket, look carefully at slightly back of the pocket.
Usually the pocket is made from something like 4140, and you'll find a braze
joint (butt braze) to the main bar.
Carbide scrap is much higher than steel, and it may pay for you to unbraze
the 2 pieces for money.
