Old 03-17-2010, 07:51 PM
Oliver Oliver is offline
Default update on Hendy lathe
Here's a picture of the lathe sitting in my shop; some pictures of old damage and repairs; and a shot of the motor that is grounded out.
1. lathe in shop
2. old weld repair of crack in way
3. old weld repair in rear of way, and pin in top of vee
4. old weld repair of crack at base of headstock; rear side
5. old weld repair of same crack at front, sorry it's blurry
OD
Name:	Hendy set up 1.jpg
ID:	58552   Click image for larger version
Name:	crack in way.jpg
ID:	58553   Click image for larger version
Name:	crack in rear way.jpg
ID:	58554   Click image for larger version
Name:	old weld in back.jpg
ID:	58555   Click image for larger version
Name:	old weld in front.jpg
"The young man knows the rules; the old man knows the exceptions" O.W.Holmes
Old 03-17-2010, 07:55 PM
Default more pics.
1. damage to apron parts; did this crash and cause the cracks ??
2. big old motor that's grounded out
Overall, pretty good shape for the shape it's in !! For what I need to do with it, and for what I will have in it, it will do. Thanks for looking. OD
Name:	the crash.jpg
ID:	58557   Click image for larger version
Name:	old motor.jpg
Old 03-17-2010, 08:12 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
It ain't in the grave yet and I think you are the man to save it. Keep us informed. That crash must have been a real disaster.
You do the best you can with what you've got.
Old 03-17-2010, 09:13 PM
Must have been a hellofa crash, those Hendys are heavy dudy.
Old 03-18-2010, 03:52 PM
engineman56's Avatar
engineman56 engineman56 is offline
Nutbuster
Oliver, Those look like some real old repairs. They been done a while ago. I don't think they are bad repairs tho. I would fix it up too. It looks like a good machine. It can't be any worse than my 100 year old Monarch. Its got some fixes on it too and it still works good.Theres still some fixing I have to do on it too. The Hendy will be a fine machine when your done with it. I like it. Kevin
It's a Normal Thing Around Here I Don't Have no Money!! Just Junk. The Problem With Most People Is They Can't Recognise A Good Piece Of Junk.
"Great spirits have always encountered violent opposition from mediocre minds."- Albert Einstien
I'm mostly worthless! You'll see.
Old 03-19-2010, 12:22 PM
Machinist-Guide's Avatar
Machinist-Guide Machinist-Guide is offline
Default Hendey
Nice lathe you have there. I also have a Hendey very much like yours
Here is a link to pcs
My Hendey
Old 03-19-2010, 03:33 PM
This Hendey is being parted out in case someone has a similar lathe and needs something:
http://www.practicalmachinist.com/vb...e-sale-196685/
http://www.practicalmachinist.com/vb...-x-8-a-200765/
Old 03-23-2010, 11:58 AM
Get some parts?
Old 03-24-2010, 09:12 PM
Default parts ??
Think so. I sent Jim a PM and he replied that some things were still available. We agreed on a couple of items, and I sent off a check tonight.
I NEED the handle for the quick change gearbox, and he had one. The cover/tray on the Q/C box must have gotten broken on mine (related to the Big Crash ?), and he had that also. it should fit; he said the 14" was different, but 16" should be the same.
I don't have a thread chart, or even a mfgr's name tag on mine (that's how I started this discussion). The one on the lathe he's parting out has an extended range chart on it; maybe 24 different speeds. One range ought to be close to my speeds, and at least I will have a tag on the machine in that spot. I can run a few different cuts to see what the tpi would be. The likelyhood of me cutting threads is pretty low.
Still looking for a motor. 220 v., 2hp, single phase is hard to find used around here. Tractor supply has a farm duty 56HZ for around $269; Grainger's has 56HZ, 145T, and 182T in increasing prices; Troy Belting (Troy Motor Service) can get me a 184 frame motor for "only" $569 !!
Gonna watch Craigslist and ask around locally for a while yet.
I'll post an update as I go along, to keep 'ya up to date.
OD
oops !! can't edit the title; left the T off. Sorry !
Old 02-27-2021, 01:37 PM
Default ‘nuther update on the Hendy
Jeez! It’s been eleven years since I first posted on this machine. I have done a number of small jobs on this lathe, but not a lot of repairs. I keep it clean and oiled because it is in an seldom heated shop, and I fight condensation and flash rust all the time.
The biggest thing I have done lately was related to my concience (sp ?). This was sitting in the corner of the JD dealer I worked at and almost never used; never for a revenue job. Just to make a tool, etc. When the boss’s father-in-law that owned the lathe died, I asked my boss if he wanted to sell the lathe. He told me to ask his BIL because it was now his. Long story short, that man is a teacher and had no knowledge of or interest in the lathe. He asked me what I’d give him for it and I threw him a low number, expecting to bargain. He took my offer!
It has bugged me since then, because I had given him way less than it was worth, even as scrap. Recently I stopped by his place and gave him the rest of what I feel I should have given him to begin with. It still wasn’t much, but I feel better about it now, and don’t feel guilty whenever I go near it.
Rock on, y’all.
Oliver Durand
