![]() The 19" long '40 Ford dash has a wireless Bluetooth speaker. Great for oldies! |
Very nice!
I love the smell of napalm in the morning. It smells like, victory! ![]() Rommel, you magnificent bastard, I read your book! Still got the shovel! Victor Torch Set With Meco Regs Lincoln Weld Pak 100 Giant Tech Arc 200 Miller Roughneck2E |
You do fine work!
Nice stuff, I love the Cobra!
The 300 SL was always my dream car.
...lew... |
Those are great.
Much better than the hand-cut (with tin snips) Mexican metal art crap my wife is always trying to drag home. |
Home made CNC plasma, you say? Any details on the machine?
Nice job on the artwork.
Equipment:
- Mig: Lincoln Wire-Matic 250, HTP Mig 200, Miller Millermatic 200 w/ spool - Stick/Tig: Thermal Arc LT-300 Tig/Stick, AHP Tig 200, Miller CST 280 - Plasma: Thermal Dynamics Pak Master 100, Herocut 50A non-HF blow-back plasma - Machinery: Jet JTM-1 Mill (needs repairs), Emco V10P lathe, Yuasa surface grinder, Ingersoll 5HP T30 #253 Compressor |
This is the second of two small plasma tables I have built for use at my home over the years. In both cases, they were designed to be used outdoors. Plasma tables are somewhat like pool tables, in that they require a fair amount of operating room on all sides. Being located outside eliminates the space issue, as well as plasma dust and debris problems. Small units like mine (2' x 2') are easy to load with material and don't require an automatic torch height control. The first table was mounted on casters, and rolled outside my garage door for use. My current table is permanently situated under a deck outside my basement door. The compressor, plasma cutter, and computer are just inside the door, and the cables can be hooked up in a couple of minutes for use. I protect it with a fire pit cover when not in use. |
Nice setup. I like the mobile aspect. Any desire for a water tray? It wouldn't be hard to add. Any electrical interference issues using the miller plasma?
I'm in the middle of retrofitting a 5'x10' router and debating whether to make it dual function as a router and plasma, or make a standalone smaller machine like a 2'x4'.
Equipment:
