#71
being the largest nose radii. But I did not want to confuse Timmy. ![]() ![]()
#72
There's an end to the saga!
Friend offered to help me out. A few minutes with a die grinder to cut out the weld and an air chisel to punch the bearing shell out... Just about good to go and lesson learned.
Tim Self appointed director of junk, and old vehicles. |
#73
I don't think you fucked it up too bad...
#74
That race driver set is a perfect lathe learning project for Tim. Sent from my iPhone using Tapatalk
#75
Nice job of welding the race to the hub. H'mm I wonder why it wouldn't come out
#76
This 3 ton arbor press that I forgot I owned should be enough to press in the new races, right?
#77
Yep, that'll do it
#78
Before you get carried away, get out the measuring devices and measure the OD of the bearing race and the ID of the bore it's going to be pressed into. Typically those things only have a couple of thousandth's interference fit (.002")
If you have to use 3 tons of force to push that race in, it will either distort the bearing or crack the bore. I put similar races in using a 2 lb copper hammer and the correct sized bearing driver.
Director of Sarcasm (by appointment) Director of Innuendo (by suggestion) |
#79
#80
Metal shards to my chest?
