SFT Search: |
View Poll Results: Why did truck bend in half? | |||
Lift placed improperly. |
10 | 47.62% |
Truck frame was weak or damaged. |
6 | 28.57% |
Excessive weight in rear from bed lift mechanism. |
4 | 19.05% |
Act of God. |
1 | 4.76% |
Voters: 21. You may not vote on this poll |
Thread Tools | Display Modes |
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) HF 80 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... Last edited by mccutter; 09-25-2018 at 09:31 AM. |
I really have no idea what you're talking about--need more info, pics, etc...
Overloaded would be my guess. Not sure if details though. Need more info.
Pictures didn't upload!
you left out Act of dodge
That failure was caused by a combination of at least three of the suggested causes.
Life beats the alternative hands down. |
weak frame
wrong lift for that size truck it’s obvious, the lift points were wrong, way too much rear over hang/weight after the rear lift point. Dodge Truck, the quality goes in, before the name goes on...... no wait that was Zenith TVs. Dodge, factory rust pre-installed at the assembly plant, so you don’t have to wait.............
jack |
No doubt lift point not centered for the weight... but I'm betting on a fractures in the frame to begin with...
and as Jack mentioned the lift is not the ideal lift for and extended truck.... Dodge have a natural tendency to fracture on their frames seen it too many times! Chevy trucks have the same tendency to develop frame fractures as well but always seem to be in the same place or within the same area where as dodge seem to develop the fractures in different places depending on the stress that is put on them and Ford trucks seem to frame fracture in the front around the gear box and or cross frame supports but don't see that too often but a four post lift could of prevented this situation but better found now than on the road carrying a load......
------------------------------------------------------------- Indipendant Biker For Ever! ; I G Y 6 I Ride For Christ M.L.L.H.& R. Support Your Local MC. Loud Pipes Save Lives Peace Out! Last edited by MetalWolf; 09-25-2018 at 10:56 AM. |
I would have to see a good frame . Back in 1980 ford put a lighting hole right behind the cab on 1/2 ton pu . Mount a big bale spike on the rear and the frame would give at that lighting hole . Lots of unhappy unwarranted claims .
It does kind of look like the double frame of the bed ends at the hinge point . |
Makes a lot more sense with pictures.
![]() One question. Why call the fire department to get the damn thing down? Not exactly an emergency situation as far as I'm concerned...
Primary failure mode: The idiot who put that truck on a 2 post lift...
Secondary failure mode: That dump bed is too big for the truck. Tertiary failure mode: It's a Dodge. (SD I am not picking on the engine.)
