Probably not proper, but I would warm up the flange with OA, weld it shut with 7018, heat again and slow cool in kitty litter. Grind smooth and drill and tap.
I have welded automotive hubs cold with no such precautions and never had an issue even after many thousands of miles of abuse.
Director of Cryptography-Upstate NY Division Last edited by Cavalry; 12-01-2010 at 06:30 PM. |
Cavalry,
Thanks for the info. I will have to run the idea past the manager who is not happy about the possible $3K drive rebuild cost. I guess if they replace the axle, numerous other drive unit parts have to be replaced at the same time or they end up with an excessive wear problem. |
Another option might be to find(if you can) a wheel stud the next possible size up on the axle threaded hole..a pressed in type stud like used on passenger cars and trucks...just ream or drill the hole out to the recommended size for that stud..then press the new stud in.
My father gave me THEE best advice ever on welding..."Welding is just like a woman son,Get'r HOT and Penetrate" Don't DREAM you're life away..LIVE you're dreams Lincoln Ranger 225 on home built trailer 2009 Miller Maxstar 200 DX Lincoln 180 Pro Mig/Fluxcore WeldCraft WP 17V 25R Flex head TIG Rig Hougen Mag drill w/slugger bits Several Makita,Metabo,Milwaukee,DeWalt grinders/cutters 4 1/2",6" and 7" and end grinders Milwaukee Porta-Band Ingersoll Rand 60 gallon air compressor |
High potential to warp the axle.
May be the machine shop that was going to drill out the new hole could make an oversized splined shoulder bolt with the same sized thread.
Mike "Yes, we did produce a near perfect Republic. But will they keep it? Or will they in their enjoyment of plenty, lose the memory of freedom? Material abundance without character is the surest way to destruction. Indeed, I tremble for my country when I reflect that God is just." Thomas Jefferson If you spent 1 million dollars every day from the time Christ walked the earth until now, you still would not have spent 1 trillion dollars! |
I think this is wheel bolts not lugs
Director of Cryptography-Upstate NY Division |
I understand where management would want to make sure they limit their liability. There is probably a lawyer somewhere who would try to convince a jury that a missing lug bolt was the cause of a lift truck loosing traction on a wet floor and injuring someone.
Another problem I have is the junk this particular lift truck manufacturer puts out. In my opinion there is way to many computers, sensors, and other un-needed garbage on these trucks. All they need to do is go forward and backwards, and lift and lower loads. I really believe that the only reason this manufacturer makes equipment is so they can create profit by selling parts. |
And keep the C/O limits under Regulation. A few years ago the rules almost were changed to ban LP lift trucks inside all buildings. We were scared as there are very few 8k electric trucks out there.
