  #1721
Old 11-28-2022, 08:22 PM
OldRedFord's Avatar
Kibble King
Personally up here we tried to avoid doing logs, wood etc unless there was snow on the ground, it helps to keep the dirt out of the bark.
Guess in Georgia that’s not really an option.
Also, habit was to cut logs 6” longer than desired board length, that allows for trimming and any checking/splitting that occurs as the log and board dry out.
The common sizes we cut were usually 8’6”, and 12’6”. Occasionally we’d cut 16’6” for 16’ lumber, but only if and when we knew we had a use for it. That long gets unwieldy to handle.
Logs are 10' 6" to 10' 9". Bar on my saw is 20" so I used that to measure.
Tim
  #1722
Old 11-28-2022, 08:23 PM
OldRedFord's Avatar
Kibble King
Getting more work done every day.
Tim
  #1723
Old 11-29-2022, 07:27 AM
randydupree's Avatar
Why, Hell Yes!
Looks good Tim.
The weather has been good for working,not hot and not cold,perfect.
And not many bugs,life is good!
  #1724
Old 12-11-2022, 07:29 PM
OldRedFord's Avatar
Kibble King
This weekends progress. This is for the light switches in the shop and power from the panel. Had to add the second conduit due to conductor full.
ID:	166468   Click image for larger version
ID:	166469   Click image for larger version
ID:	166470   Click image for larger version
ID:	166471   Click image for larger version
Tim
  #1725
Old 12-11-2022, 07:36 PM
OldRedFord's Avatar
Kibble King
Last weekend I replaced my walk door for one with a window and replaced the wood siding with cement board. Still have to put the window back but I'm happy with the outcome.
ID:	166480   Click image for larger version
ID:	166481   Click image for larger version
Tim
  #1726
Old 12-13-2022, 04:52 PM
OldRedFord's Avatar
Kibble King
Septic system was installed today. Tan was moved over because bedrock was found 24" down.
ID:	166502   Click image for larger version
ID:	166503   Click image for larger version
ID:	166504   Click image for larger version
ID:	166505   Click image for larger version
Tim
  #1727
Old 12-13-2022, 04:54 PM
OldRedFord's Avatar
Kibble King
A few more pictures.
The leach field was located farther from the building then I'd like due to finding more rock. Glad I removed those trees.
ID:	166512   Click image for larger version
ID:	166513   Click image for larger version
ID:	166514   Click image for larger version
ID:	166515   Click image for larger version
Tim
  #1728
Old 12-13-2022, 06:03 PM
Do yourself a favour, go place some rocks just outside the field while you know where it is. They can be markers for down the road to know where it’s located. And maybe placed so that the area doesn’t get drove over.
  #1729
Old 12-13-2022, 07:32 PM
OldRedFord's Avatar
Kibble King
I was thinking about that but with T-posts.
Tim
  #1730
Old 12-13-2022, 07:35 PM
Do I have a life?
Be careful driving over the tank and field... How much weight can the tank, etc. hold?
HF 80 lunchbox w/tig
