Old 07-07-2005, 06:57 PM
banzaitoyota banzaitoyota is offline
Send a message via AIM to banzaitoyota
Default Cuting Torch Problems: Technique or Equipment
hmmmm. Where to start. Went out to the shop needed to cut some 3/8" plate. Results were horrific. Dross kept filling in the kerf, no matter what speed or O2 Pressure I used.
Being easily frustrated lately I left the shop in disgust at my lacking abilities.
Now, thinking about it I think I may have caused the problem. I used my Regulators (Victor : acetylene #150-15-510 0781-8981 & Victor oxygen #150-60-540 0781-8980) which were purchased to be used with my Mecco Midget Torch outfit.
Is it possible that these regulators dont flow enough to cut 3/8" plate correctly?
Old 07-07-2005, 07:25 PM
b-footn's Avatar
b-footn b-footn is offline
Yes girls, he's single!
I use a fuel gas called HPG, similar to MAPP gas. I have the fuel gas pressure at around 8psi, and the oxygen around 45 psi. Depending on what tip you have in the torch, adjust your fuel until the orange flame just leaves the tip, and then add oxygen for a perty blue flame, with no feathery blue extending from the main blue flame. This is max flow of the tip. Your speed after starting the cut, is determined by the tip size. Stay in the cut line and adjust your speed to the flow of molten metal blowing on the bottom side. Angle your torch tip in a forward position so that you are pre-heating the metal in front of you.
You were probably trying to go too fast for the tip in the torch.
Old 07-07-2005, 07:30 PM
7018's Avatar
7018 7018 is offline
What did you have them set at??????acetylene at 5# oxygen at 20# that should do the trick.Clean Tip??????If the ox reg is holding when you start the cut it should work.Don't hold to much of a angle for 3/8 I only angle my tip on gauge metal.....Hope this helps...
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
Old 07-07-2005, 07:33 PM
Tip is clean, O2 at 24#, Acytylene at 5#
Old 07-07-2005, 07:43 PM
b-footn's Avatar
Looks like my oxygen pressure is set too high. (NOT)
Old 07-07-2005, 07:48 PM
7018's Avatar
Different setting for different peeps I guess,But I do most of my cutting at those settings..
Old 07-07-2005, 08:16 PM
b-footn's Avatar
Me like to travel as fast as possible
Old 07-07-2005, 08:34 PM
Markopolo's Avatar
You might look at travel speed banzai...........If your tip is clean (preheat AND cutting holes), it should work.
Also, you might look at the steel you're cutting.....if it's really rusty or dirty, that might make a difference......and what position are you trying to cut ?....vertical ?....horizontal ?....overhead ?.....or just flat ?
I use 5 lbs. on the Acetylene, and 30 lbs. on the 0², and with a 0-3-101 Victor tip, (0 size).....I can cut 3/8" plate like a hack-saw...... BEAUTIFUL CUT !
Jezynowka !
Old 07-08-2005, 09:18 AM
fatfrank fatfrank is offline
Pit Boss
Maybe you didn't use the correct tip size for that plate?????????
Old 07-08-2005, 10:20 AM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
Something else about clean tips,,, is this a know good tip or a "community" hammer. Tips can get ragged in the lance hole and never clean up, I can even feel it when using a tip cleaner. I was cutting with one a while back, scrapping and spend a half a day with a crummy tip, I finally pitched it in the woods, what a difference. They get hard crust built up iside that doest clean out.
