Old 08-21-2011, 01:18 AM
mtnkrake's Avatar
mtnkrake mtnkrake is offline
Default Scored me a Nugier press
I scored a Nugier H25-7 air over hydraulic 25 ton press for $150. This is one heavy duty sucker. It almost killed me to unload this beast by myself. I shouldn't need much to get it pumping. The air part moves the ram but the hand pump doesn't build pressure. It seems as though it needs a cup in the pump or something. Anybody out there have one of these? An owners manual and a parts list would be great. Time for some cleanup and paint.
ID:	80436   Click image for larger version
ID:	80437   Click image for larger version
ID:	80438   Click image for larger version
Old 08-21-2011, 01:37 AM
matthew_g's Avatar
matthew_g matthew_g is offline
That's about the same size as mine, But I only have a hand pump setup on mine, So I'm not much help really am I.
But for $150 you did well as mine was around the $600 mark.
Matt
A society grows great when old men plant trees whose shade they’ll never sit in.
Old 08-21-2011, 01:49 AM
Rotty, you really just gotta paint that gauge before you put one of these guys eyes out!
Old 09-07-2011, 03:22 PM
mtnkrake's Avatar
Default almost there...
Well I got the pump rebuilt and mounted but the ram wasn't holding pressure. So I took the ram apart and the main seal had turned to dust. I guess it is to be expected on something that is at least 35 years old. New seal kit is on the way and it should be good for another 35 years. Ill take some pictures when I get done.
Old 09-07-2011, 07:54 PM
seagiant's Avatar
seagiant seagiant is offline
Hi,
YOU SUCK! I paid $75 for my Carolina 30 ton with no press and was tickled to death!
Old 09-15-2011, 08:06 PM
mtnkrake's Avatar
Well I finally got it done. As usual with my projects it went a little over budget. I paid Nugier to rebuild the pump because somebody was inside it before I got it and they don't have any diagrams for this style of pump. With no way to know if I was putting it together right I thought this was the way to go. I rebuilt the ram and it holds pressure. Its not a true air over hydraulic its a hydraulic with an air blow down valve. It works great, blows down to the work then you pump to build pressure. Here are some pics.
ID:	81489   Click image for larger version
ID:	81490   Click image for larger version
Name:	Press pictures 011.jpg
ID:	81491   Click image for larger version
Name:	Press pictures 008.jpg
ID:	81492   Click image for larger version
Old 09-15-2011, 08:39 PM
bd354's Avatar
bd354 bd354 is offline
Damn,you did a good job on that gauge. Nice score and looks like new now.
Life is easier if ya plow around the stump
Never drink downstream from the herd
Old 09-15-2011, 08:40 PM
Mild Steel's Avatar
Mild Steel Mild Steel is offline
I would say your rebuild costs are well worth it. It looks great! Now that the press belongs to someone that cares about it, it should last forever.
Still trying to be the man my dog thinks I am.
Old 09-15-2011, 08:48 PM
It's a gorgeous thing, rotty.
Old 09-15-2011, 09:23 PM
getatorch's Avatar
Tuned-Up Big Builder
Very nice work there. You have a treasure there.
"Freaking" is what you feel when things go wrong. The other word really refers to what happens when things go right... That one is only bad if it's against our will".
Tags
h25-7, nugier, press
