I need some expert
I uses fence wire strung thru some holes in the purlins for additional support of the insulation to keep it from sagging. I bought a roll and it was enough for a couple buildings. Pulled it tight and anchored it on both ends, this runs perpendicular to the purlins. I could roll it out right in place, fold and staple. There is splice and patch tape for this insulation and it works very well, you can put pieces together no problem.
We used a sheet to support one side. It doesn't show here but in the 3rd pic the insulation stops at the lean to but about where Zeke's right hand is there is a smooth fence wire runs all the way across the build under the insulation, roll it right out.
We actually went back and installed the roof mastic after the fact, had screw holding the far edge, lifted the sheet and rolled the mastic in with a dispenser tool we made, so much better than by hand. We let the sheet flop back down and could come by and strip the backing paper, it had pinch roller to press the mastic down and was wayyyyyy more accurate and wayyyyyy faster than doing it by hand, about 30 seconds to install a 40 ft run. 40 ft sheets on this project.
The wire just keeps the sag out and holds it up a little forever, well worth the effort. I spaced them 3 ft apart, a foot past the seam, the insulation then can droop only so far, in the long run this was a good idea. We made cradle for the sheets, drag them off on to the roof. We had pretty good system by the time we finish. Wind can be a problem.
I have done this job several times in my career, it went so much better when I was the boss,, hahaha really because I was willing to wait till we were ready and work out some details vs just ramming ahead. |
just more bs.
Thanks, Sberry, this insulation I am told already has the mesh reinforcement in the plastic covering. Once before, on the fairgrounds building we used 6 foot wide chicken wire. Almost got into a knock down drag out fight with my partner putting it up !!! I'm hoping with the reinforcement already in the roll it will be easier !, thanks, Ken
