Old 02-04-2020, 03:16 PM
Default Oh boy Oh boy Oh boy !
https://altoona.craigslist.org/tls/d...060166449.html
Old 02-04-2020, 07:00 PM
Norm W's Avatar
Norm W Norm W is offline
Powered by a "Driptroit" engine. Every time you strike an arc "Screamin' Jimmy" sings you a tune.
Old 02-04-2020, 07:35 PM
That doesn't seem too bad of a price for my area. I see a lot of clapped out SA200s going for that.
Old 02-04-2020, 08:13 PM
randydupree's Avatar
Why, Hell Yes!
that thing is old.
The last time i saw a detroit welder was in 1980,and they were old then.
Old 02-04-2020, 08:25 PM
So what is under the cover the arrow is pointing at?
Old 02-04-2020, 09:31 PM
That does not look like a 271 to me....
Old 02-04-2020, 10:53 PM
what it is is a crapped out machine with a 2 quart overhaul.
It is a two cylinder and the -71 would make the correct HP while polluting both the ground and the air. Around here we would call it a levitrite.
The exciter end is under the cover but I believe that the arrow points to the "made in USA "
Old 02-04-2020, 11:10 PM
Don_S Don_S is offline
It's definitely got a blower on it and appears to have a Detroit Diesel symbol on it. The exhaust side of the head looks weird. It appears it may have glow plugs. The internet has mixed answers on Detroit 2 cycles with glow plugs. Appears that some 2-71's in generator service may have been equipped based on an add for glow plugs for a Detroit.
It does resemble the 2-71 I found on ebay. The fuel pump is the same.
Name:	2020-02-04 21_45_16-Lincoln Diesel 400 amp welder - tools - by owner - sale.jpg
ID:	154607   Click image for larger version
Name:	2020-02-04 21_47_19-Lincoln Diesel 400 amp welder - tools - by owner - sale.jpg
ID:	154608   Click image for larger version
Name:	2020-02-04 21_58_35-Detroit Diesel GM 2-71 , 30 kW Marine Diesel Generator 271 _ eBay.jpg
Old 02-05-2020, 01:20 AM
access to the exciter's carbon brushes.
Old 02-05-2020, 06:52 AM
A friend (former) has one, and there is no auto idler.
throttle is on top of governor cover, mushroom wheel marked stop, idle, run.
I used it (once) to put grab hooks on top of his loader bucket, and he didn' thave any leads with it, so I brought some of mine.
They were maybe 20' long.....I couldn't hear any type of arc, and kept
having thoughts of being run over by a "city bus"....
