Old 01-18-2020, 04:37 PM
tnfarmboy tnfarmboy is offline
Default Tired old welder
I have a very old P&H Welder. It has served me well for several years. I have noticed for a while now that it has been getting weaker. I haven’t used it in a while. Today I needed it and it was hard to keep a 3/32 6013 lit. That’s with it turned up all the way on AC, should be 480 AMPS, maybe not with 220V, but still... I tried DC+ & DC-, same or worse. A few years ago I could write my name in cursive with that same rod on DC- with the juice way lower. I’m running it on 220V.
I would guess it’s just junk now that’s not worth trying to fix. Could it be something relatively cheap and easy?
Thanks,
DD
Old 01-18-2020, 05:31 PM
Twice the size--half the man
Welcome to SFT tnfarmboy!
I love the old welders, though I have little experience with them. One thing I'd suggest is pulling the cover off and giving it a look-through. Might be something as simple as a dirty or corroded connection that's readily obvious. I have an old Craftsman ac/dc rig that the dirt dobbers LOVE to build nests in. Fire ants also love the taste of the old insulation. Occasionally it'll just stop working for no reason and a little bit of cleaning will get it back up to speed in no time.
I'm not familiar with that model, but someone else may come along and have a lot more information for you.
Wade's Custom Kydex
Old 01-18-2020, 06:16 PM
Welcome!!
Old 01-18-2020, 06:22 PM
astronut's Avatar
astronut astronut is offline
Welcome to the forum! Sorry but I have no answers that help you with that machine.
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 01-18-2020, 07:30 PM
Thanks,
DD
Welcome to the Site.
First,
I thought P&H welders were suppose to be Yellow.
I would Likely guess a cheap fix, but really need to see whats inside.
I would guess the reactor is not getting its full DC supply voltage.
As stated above a bad connection.
I would first check the brush on the rheostat (assuming it is that old).
may find a drawing glued to one of its inside panels. that would help.
Old 01-18-2020, 10:24 PM
Thanks for the replies and welcome. I will definitely pull the cover and check it out.
Old 01-18-2020, 11:45 PM
First off, check your cable connections. Make sure they seem tight, and not loose or corroded.
If you have an ohm Meter, check continuity thru the welding leads.
If that seems to be good, then start taking covers off. Don’t scrap it yet. It is worth looking further for the problem.
Old 01-19-2020, 03:40 AM
As others have said, pull off the cover and make sure everything inside is squeaky clean. Blow out all the dirt and take some fine emery cloth to every metal to metal contact point. If you're not getting full power because of loose or poor connections you may see signs of arcing--pay particular attention to the rheostat...
Old 01-26-2020, 11:34 AM
That may be one that "chokes" the current with the small rheostat.
If so, there will be some selenium rectifiers (any smoke come out lately ?)
providing d.c. to that rheostat circuit.
Also, is there a "local/remote" switch ?
It's apparent that the current control is not working.
