Old 01-05-2020, 01:58 PM
Scratch Scratch is offline
Default My first metal lathe!
A relative (Greg) passed away recently and he had a metal lathe that they didn't know what to do with. They knew I was into metalworking and asked me if I wanted it. I hadn't touched a metal lathe in like 30 years since high school but have always wanted one so I gladly said yes without even seeing it.
They dropped it off yesterday and I thought I'd share some pics. I do have some questions though as even back in high school I didn't use one much. I do still have the one project I made back then, which was a center punch, but that's about my only experience with them, so please correct me if any of my nomenclature is wrong.
Greg made a nice heavy duty table for it, and it looks like he made the motor mount too. It looks like it's a 24" lathe, with a 4 jaw chuck, which I think is more desirable than a 3 jaw...? It has the tailstock but no live center or Jacobs chuck. They should be easy to find shouldn't they?
ID:	153771   Click image for larger version
ID:	153772   Click image for larger version
ID:	153773   Click image for larger version
Old 01-05-2020, 01:59 PM
It looks like this lever on top is for engaging the back gears to get low speed, and if I loosen up this bolt I can separate the head from the pulley to actually use low speed, but shouldn't it just be a pin instead of a bolt? When I loosen it, the square "nut" inside, which fits into a square hole on the pulley, just kind of rattles around when the head is spinning. It's also a pain to get lined up and into that square hole again. Am I doing it wrong or something?
ID:	153775   Click image for larger version
Old 01-05-2020, 02:00 PM
It looks like this lever is for engaging the automatic feed, but I'm missing some of the gears to make it work. I do have one loose gear you can see in the pic, but I can't find where it goes, and have no others. Am I able to get more of these gears to get the auto feed working again? Also the lever on the carriage doesn't seem to want to engage the threaded rod correctly. I haven't opened it up to see what's up, but it doesn't seem to be working right now.
Also the hand wheels for the carriage and cross slide are very tight. I've lubed them up but they're still hard to turn.
They gave me a toolbox tray full of random parts that they thought went with it, but I don't really know what they are for or if I'm missing some stuff. I'd love some help with that too, here's a pic.
Old 01-05-2020, 02:01 PM
What are some other things I might want for this besides a live center and Jacobs chuck?
I was thinking I could get a milling attachment for it, since I think I might use a mill more than a lathe anyways.
Should I get a 3 jaw chuck or not?
What about a compound rest?
Or is this thing just a piece of junk and I shouldn't put any more money into it?
Old 01-05-2020, 02:05 PM
GabZip's Avatar
GabZip GabZip is offline
your box of parts are hold downs for a mill Sorry to say
Old 01-05-2020, 02:08 PM
Good to know... thanks. Although I didn't think he had a mill, so not sure why he had those.
Old 01-05-2020, 02:14 PM
Is there an ID plate with a name? Then you could likely find a manual.
Woodrow Wilson
Old 01-05-2020, 03:01 PM
The only text I can find on it is on the back of the bed and it says:
Pat'd September 21 1880
Pat'd February 15 1887
Old 01-05-2020, 03:35 PM
Having a lathe is better than no lathe.
Nice starting size.
I like the ingenuity of the tool post lower screws for height adj.
If you have a choice for free then a 4 jaw chuck, but you need both 99% of the three jaw chucks are self-centering and what is used most.
1) Looks like you have a missing tooth? if so don't engage the back gear.
