  #31
Old 01-06-2020, 09:30 AM
I bet you were running DCEP and not DCEN.
I have diagnosed that problem more than a
few times.
Nope.
I was on electrode negative. That was the first thing that welders said when I asked for advise on it.
As it has a very weak gas shield a slight breeze, even intermittently, can ruin your weld
And dirty steel embedded with rock and minerals, is hopeless as there is not enough flux to trap impurities.
I went to 1/4" 7018 for the job, and it was perfect.
I then took the rolls home and tried to figure it out, and eventually scrapped all the rolls.
It can't compare to bare wire and gas....if it could every fab shop would use it.
  #32
Old 01-06-2020, 11:11 AM
Nope.
And steel embedded with rock and minerals, is hopeless as there is not enough flux to trap impurities.
I ran a lot of 1/4" back in the 70s and used a old GE AC welder with the crank on the top to run it. And it was pretty
  #33
Old 01-07-2020, 11:00 AM
Originally Posted by rustythe4x4 View Post
I run.035 flux core. Have for years. I can make some pretty welds, and I've made welds I've been so embarrassed by I ground them out and redid them.
Flux core isnt just for your crappy 110 volt harbor freight machine... i run it in my CP250/S52 100% duty cycle Miller, and it makes a HUGE difference. I'm no professional, but i can pretend.
Bottom line, i run it because I'm CHEAP. Its about 1/3 the price. I have also been running without the shielding nozzle (just bare tip) for several years now. Its cleaner, and you can get into spots you cant when running it.
In no way am i endorsing to abandon shielding gas, I'm just saying you can do it with success. It's like any process. The more you practice it, the better you get.
I agree with you.
I run 0.045 and 0.062 and I have the FC gun that Miller makes. I run it off my TB 302D and my MM 350P.
I get great welds with self-shielded wire.
  #34
Old 01-12-2020, 08:58 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
21b works ok, but my go to is either coreshield8 or nr233
Jeff
