Old 10-27-2019, 06:43 AM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
Default New shop
It's taken a long time to finally get here but things are finally coming together. 30x40, 12 ft walls, 12 ft roll up door and a 6 inch concrete slab. I'm doing a minimal wiring job this week and then my tools start moving in.
The old corn crib to the right will become my new blacksmith shop. It needs some structural reinforcement but it's got a lot of character.
Klaatu barada nikto
Old 10-27-2019, 07:19 AM
Good for you!!!!!!!!!!!!
Old 10-27-2019, 07:38 AM
Is going to feel good to get your tools in.
Word of warning, through. I heard the term 'minimal wiring.' I did the same in 2009 and I am still running extension cords across the floor to power the plasma and such. There is always something to do and finishing gets put aside.
Old 10-27-2019, 08:17 AM
tnmike's Avatar
Sultan of Scrounge
One light switched at the man door and one gfci outlet. That is the NEC minimum. The main reason is to get the inspector out of my business.
Klaatu barada nikto
Old 10-27-2019, 09:39 AM
Woodrow Wilson
Old 10-27-2019, 11:36 AM
tnmike's Avatar
Sultan of Scrounge
I was talking to a local electrician here the other day. A normal new house requires around $7,000 in material to wire. That figure does not include labor. I have a degree in electrical engineering and have not taken an NEC code class in some time. I don't keep up with it and don't want to. That being said, some of the changes are just stupid. It's no wonder it costs so much. I won't get into arc fault breakers but will discuss this. All switches now require a neutral be run to them whether it is used or not. If it's a single pole switch you cannot run a 12/2 romex cable to it and mark the white wire black. A 12/3 must be run and the neutral terminated in a wire nut to accommodate future automatic switches. Another idiotic change is gfcI outlet's in garages even overhead outlets that cannot be reached. Ie garage door opener or plug in shop lights. It's changes like this that are driving the cost up. Its regulation run amok.
And my final opinion for the day is: I will never put a freezer on a gfci outlet. I don't care where it is. Too many breakers and outlets are made in China and are prone to nuisance tripping. The power quality of my REA is beyond terrible and contributes to the problem. Take that for what's it's worth. I have learned the hard way
Klaatu barada nikto
Old 10-27-2019, 12:12 PM
We had a power outage here the other night for about an hour during a windstorm. When it came back on, we were short one bathroom light, and one bedroom light. The GFI outlet in the OTHER bathroom had tripped and needed to be reset. Go figure.
Old 10-27-2019, 01:07 PM
tnmike's Avatar
Sultan of Scrounge
It takes 5 ma of current to trip a gfci outlet. The REA here has so many loose and missing neutrals it's amazing. Guess where some of that return current goes? They left a span of primary distribution neutral that had broken lay on the ground six spans above my house for a year.
It may work in a perfect world but in an imperfect world it may not. I am not going to risk a freezer full of beef to find out.
Klaatu barada nikto
Old 10-28-2019, 07:46 AM
RonL's Avatar
RonL RonL is offline
Nice shop!
The problem is that with open space everyone has something that needs to be put somewhere. Soon, you're tripping over "stuff".
It is nice to have a place to work.
RonL
Big Blue 500 CC/CV
CST 280
Hypertherm 1650
Suitcase 12RC
24A Feeder
Thermal Arc 160S
