Old 10-22-2019, 10:41 PM
We have the three numbers.
I have a select few oil seals on the shelf at work. I could check to see if I have them in stock. If you can post the numbers.
Old 10-23-2019, 08:56 AM
I will post them when I get back from taking the missus to a doc appt. in Colorado.
Old 10-23-2019, 06:39 PM
The Timken seal numbers are:
658510
659008
658808
Old 10-23-2019, 07:27 PM
I had good luck several years ago with a place in the states called Seals Unlimited, very knowledgeable, good pricing and shipping.
Sent them an email with numbers for a quote.
Old 10-24-2019, 11:37 AM
I would need to know the of the shaft being sealed, the bore that the seal presses into, and the width of the bore.
Old 10-26-2019, 06:59 PM
There are 4 seals. All metric. Thickness 10.0. Dimensions below:
1. ID 74.0 OD 100.0
2. ID 60.0 OD 89.7
3. ID 64.7 OD 84.9
4. ID64.70 OD 87.8
Old 10-26-2019, 07:31 PM
Is the ID the shaft size?
Old 10-26-2019, 07:54 PM
Found one of your seals here by rounding your shaft size 64.7 to 65 mm part number 24060-0710 Hold down the control button and then the f key and type in the number
Old 10-26-2019, 10:19 PM
Ya got some oddball seals there. I looked in my old book, and these are the closest I could find. Nothing matched 100% though.
ID:	152704Click image for larger version
Old 10-27-2019, 08:55 AM
Yes, shaft size. All dimensions were taken from shaft or casting bores.
