Old 10-21-2019, 03:59 PM
Took the two inboard seals that were leaking down to my local parts house and after measuring he came up with two Timken P/N's. Neither one is listed as current. He is calling Timken today and will let me know if he can get them, or a replacement P/N.
Old 10-21-2019, 05:11 PM
Pics of the spindle and two bad seals.
Old 10-21-2019, 11:13 PM
I had good luck several years ago with a place in the states called Seals Unlimited, very knowledgeable, good pricing and shipping.
Old 10-22-2019, 10:26 AM
Thanks.
Old 10-22-2019, 11:08 AM
Chris, I would still go with a light grease, even if you get new seals. The old 9" South Bend lathe I learned on at school had grease cups, mind you they were bronze bushings too.
Old 10-22-2019, 02:52 PM
Exactly my plan. So far the parts guy says Timken does not stock the number and there is no new P/N for the two inside seals. He has a couple more places to contact yet. It may be that I will have to fab a new inner plates with O rings to eliminate the seals.
Old 10-22-2019, 06:04 PM
What size are the seals you need?
Old 10-22-2019, 06:31 PM
Camaro Zach's Avatar
If you look the old seals over with a magnifying glass you may be able to find a part number on the inner/outer lip molded into the rubber.
I saved a friend’s old brush hog gearbox by doing that and finding a number on the old seals. Nobody could track down a replacement by size, auto parts store even had it in stock.
Buggy
Old 10-22-2019, 07:47 PM
You need three numbers to select a seal.
shaft diameter
seal seating bore and seal thickness. Unless one of those numbers is non standard an off the shelf seal will be available.
It may not have a number that matches the factory seal but who cares
Old 10-22-2019, 09:25 PM
shaft diameter
We have the three numbers.
