  #971
Old 01-28-2020, 11:08 PM
Stairs are easy,7-11 is my favorite,if you have room.
I have big feet.
You will be using them the rest of your life. Use extra room to make them comfortable to use, especially if you will be carrying things up and down them. You can always build good storage area under them .
  #972
Old 01-29-2020, 10:13 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
I broke down and bought a framing nailer off Amazon. It's a Metabo HPT NR90AES1. Should be here Wednesday. I haven't much experience with a framing nailer but I'm sure I'll figure it out.
Don't use it while pointing towards your body
point the air exhaust away from you and if it's dirty/dusty consider safety glasses. it's quite possible to blow dirt right back into your face using them.
for a man that knows nothing about them I think you bought a good one.
  #973
Old 01-29-2020, 12:20 PM
OldRedFord's Avatar
Kibble King
I'd like my finished treads to be 11-12 inches deep, 6-7 inch rise. The stairs will be 48" wide. There will be storage under the stairs. Part of it will be my kitchen pantry. I'm hoping 16 foot long stringers will be enough.
Tim
  #974
Old 01-29-2020, 03:16 PM
What is your overall height floor to floor?
  #975
Old 01-29-2020, 03:21 PM
Used 8’ floor to floor height in my calculator and came up with the following numbers
ID:	154458Click image for larger version
ID:	154459Click image for larger version
ID:	154460Click image for larger version
ID:	154461Click image for larger version
  #976
Old 01-29-2020, 04:02 PM
Gazza's Avatar
Gazza Gazza is offline
This is one part of your build where your floor is your friend.
Set out the rise/run of the steps and the stringers at actual size on your floor, make any adjustments to make it all work, then cut everything out knowing that it will fit correctly.
  #977
Old 01-29-2020, 10:15 PM
When I build stairs I do not cut the stringers instead I build a laminated stringer using 2 2X6 outside plates.
I rip all the risers and cut them to rough length of run + 12 inches. The stringers are cut and fitted to the opening two per finished stringer.
The first rise is shorter by the thickness of the tread to make all rises the same.
Put the short riser on one stringer with the tread width less kick space then fasten each riser tight to the one below with the same stick out. After all risers are placed place a second riser on top and nail it on.
when youj are finished your riser will have 2 uncut 2X6 stringers and will be far stronger than a 2 X 12 with chunks cut out.
Unless you have laid out and cut stair risers often this method will also be faster and cheaper.
When you make the first one just use one nail in each piece onto the stringer. put it in place and check fit that way you can fix it if it is wrong.
Once you know it is right nail it solid and put the cap riser on also well nailed.
Use that as your pattern for the other riser (s) in that stair.
With a cut 2 X 12 riser if it is wrong it is usually firewood
  #978
Old 01-29-2020, 10:25 PM
OldRedFord's Avatar
Kibble King
Overall height is 109 1/2 finished floor to finished floor.
Tim
  #979
Old 01-29-2020, 11:06 PM
Here is what I got for 109", 7" rise and a 11" run.
Rise 7 inches or 17.78 cm
First Step Height 4 inches or 10.16 cm
Total Run 13 feet 9 inches or 419.10 cm
Number of Steps 15
Stringer Length 16 feet 1.98 inches or 492.71 cm
Stringer Height 8 feet 6 inches or 259.08 cm
Angle 32.47°
Woodrow Wilson
  #980
Old 01-30-2020, 12:39 AM
New calculations Click image for larger version
ID:	154469Click image for larger version
ID:	154470Click image for larger version
ID:	154471Click image for larger version
About 16’3” long stringer lengths.
Terry idea sounds like it may work too.
