  #31
Old 02-06-2020, 11:02 PM
Don_S Don_S is offline
If the piston screws onto the rod, assemble them and drill a hole at approximately the pitch diameter of the thread through both the rod and piston. I wouldn't go all the way through. You could either tap it for a setscrew or just put a pin in it and peen the hole over to keep it from escaping.
It will not come loose if you keep the pin in place as it has to shear the pin across its length.
