![]() 300 amps @ 60% duty cycle 50-700 ipm, adjustable wire speeds solid wire sizes .023-.068" / fluxcore .045-5/64" / aluminum .035-1/16" Preflow timer .1-1 sec / postflow timer .1-5 sec 28 lbs weight, designed to fit down a utility manhole 8", 11-12# or 12", 44-45" wire spools I've used this wire feeder many times, and have had great results, with both Lincoln and Miller gas drives. My main power source is a Lincoln V-350pro, but have also used with great success a Miller XMT-304, and have in an emergency powered it with a Lincoln AC/DC buzzbox. Jack http://www.mylincolnelectric.com/Cat...eet.aspx?p=421
jack Last edited by platypus20; 01-14-2008 at 10:04 PM. |
I had a friend come across one "cheap enough" and asked me about running it on his Dial Arc (was mine)....at first I told him I'm not sure, but doubt it....I was @ my LWS later and asked one of the "oler guys" there and he said sure can...... he hasn't hooked it up yet what does he need to do so?...
Thanks, Mike
"We will fight them there or we will fight them here." Marine Lance Cpl. Matthew Medlicott(KIA Aug.25,2007)Semper Fi Brother A veteran is someone who, at one point in his life wrote a blank check made payable to The United States of America for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it. |
Mike,
Run the positive lead from the welder into the feeder, run the negative lead from the welder to the work, run the voltage sensing wire from the feeder to the work. Hook up the gas, set the CV/CC switch to CC, turn the power on, make a rough adjustment to the welder amps, the adjust the wire speed to get the best weld puddle. If you going to run fluxcore, run the positive lead to ground, the negative to the feeder, and make your adjustments, then weld . Does he have a manual, it can be downloaded fron Lincoln. Jack
jack |
I couldn't ever get mine to work right with the old lincoln AC/DC, I tried every combination I could think of.
Dixieland Welding |
platypus20
Can the LN-25 be ran with flux core wire out in the field? Thanks. |
NM,
Yes, I run fluxcore with it all the time, all it takes is switching the welding leads polarity, compared to regular mig welding. Jack
jack |
I have a 25 that I run off of my GXT, I use Hobart fabsheild gas-less flux core and it works fine out in the feild. Tim
I run dualshield and fluxcore off my LN-25, and have never had a bit if trouble with it. I got it used off Ebay a few years ago.
Jeff |
