Old 03-14-2021, 12:29 PM
OldRedFord's Avatar
Kibble King
Default Electrical service questions
Can I put USE-2 aluminum wire in conduit?
I'd like to run 4/0 aluminum from my meter to each 200 amp disconnect. Got some of this left over from my temporary power run to my building.
4/0 for my two hots and neutral. #4 copper for ground.
Tim
Old 03-14-2021, 01:53 PM
I used 4/0 aluminum wire in PVC conduit for service wire to a 200 amp panel for the sons shop. Not saying it is code compliant, just sufficient for his purpose. I did not ask anyone. Thankfully, we do not have inspections here. The only reason for the conduit is he has a few ground squirrels at his place.
i
Old 03-14-2021, 02:03 PM
Around here service entrance is 4-o from meter base to service panel or from disconnect to service panel if more than 6 ' from meter base . This is a electrical supplier requirement in or town not local code . for a 200 amp panel .
Do you have enough room at service to get 2-4-o hooked up . for both panels ?
Old 03-14-2021, 03:57 PM
OldRedFord's Avatar
Kibble King
Yes theres room. For up to two 250mcm wire.
Tim
Old 03-14-2021, 04:50 PM
Norcal Norcal is offline
If it is URD cable, no, at least inside a structure it is going need another rating like RHW, as URD is not allowed in a building.
Old 03-14-2021, 07:53 PM
OldRedFord's Avatar
Kibble King
Is there a different way to attach schedule 80 pvc that will seal from rain? Or is the way I have it standard practice?
ID:	159856   Click image for larger version
Tim
Old 03-14-2021, 08:16 PM
I honestly don't know about Sparky's standard practice. But, a bead of silicone on the shoulder of that fitting before you run up the nut inside the box should seal it pretty good. Just my 2 cents.
Old 03-14-2021, 08:40 PM
Scotts Scotts is offline
Sealing gasket put on adapter then through the box then locknut. Not sure pvc conduit needs the plastic thread covers like metal conduit does.
https://amftgs.com/sealing-washers-sw-series/
Found some sealing washer info.
Old 03-15-2021, 05:31 AM
Default service questions
sealant not required on these conduit fittings.
Purple primer is for plumbing fittings,not electrical..just glue next time.
Bushings not required for the PVC conduits.
Old 03-15-2021, 11:24 AM
Thanks BC
